MySkoda - Only 1 entity after installing, how to get started?
I have installed MySkoda from HACS
skodaconnect/homeassistant-myskoda: Homeassistant integration for MySkoda.
Its supposed to give me all sorts of entities, but I only get one named MySkodaUpdate. Any tips on how to get startet, how do i log in with my user etc? The GIT page does not explain it for a newb :cry:
Hello Remiandre,
If you have a problem with a specific custom integration, your first step should be to check the original GitHub post where you found it. The people there know the product and use the software, so they can give you better help with your issue. You might find someone here who can help, but it’s not guaranteed.
Thanks for the tip. I found it on the URL I pasted. It does not contain any info on how to get in contact with them besides Discord, guess i will have to join there then :confused:
I was stuck at exactly the same position as you. I couldn’t find the very simple but necessary piece of information on Github. After you’ve installed the repository via HACS you also need to go to Settings → Devices → Integrations → and click add Integration and select MySkoda.
After this I’ve suddenly had a whopping 53 entities :slight_smile:
