I had my db running on external MariaDB for months. As it was version 10.4. I had a message to upgrade this. During that I messed up my db and decided to start over.
I started my mariadb with:
* CREATE DATABASE homeassistant;
* create user 'hass' identified by 'supergeheim';
* GRANT ALL ON `homeassistant`.* TO 'hass'@'%';
* FLUSH PRIVILEGES;
I can access this db from my Windows with HeidiSQL. Starting HA I can see it seems to start initialising that db, but results in an error. Can someone please help?
Database error during schema migration
21:54:28 – (FEHLER) Recorder
Error executing query: (MySQLdb.OperationalError) (2013, 'Lost connection to MySQL server during query') [SQL: CREATE INDEX ix_states_event_id ON states (event_id)] (Background on this error at: https://sqlalche.me/e/14/e3q8)
Adding index `ix_states_event_id` to database. Note: this can take several minutes on large databases and slow computers. Please be patient!
21:54:28 – (WARNUNG) Recorder
Database is about to upgrade from schema version: 4 to: 33
It is consistent the same SQL call CREATE INDEX ‘ix_states_event_id’ across multiple restarts, so I don’t think it is a real connection issue.
Lost connection during query can mean a number of different things, but given adding indexes can take a while, chances are the connection is timing out before its complete.
you can check the current timeout value by running SHOW VARIABLES LIKE "%timeout";
IIRC, connect timeout default is only like 10 seconds, you probably want it more like 300 or 600. SET GLOBAL connect_timeout = 600;
If all else fails, try running the query manually.
The timeout was set to 10s as you expected. I changed it and tried again, with exact same result. I also run the query directly on my MariaDB host machine. But it can’t run it either:
root@localhost [ha]> CREATE INDEX ix_states_event_id ON states (event_id);
ERROR 2006 (HY000): Server has gone away
No connection. Trying to reconnect...
Connection id: 3
Current database: ha
ERROR 2013 (HY000): Lost connection to server during query
Any ideas on how to go on?
edit: during my research I found that it might be due to a large packet transmitted. The standard size in my db is 16mb, but I’m not able to increase it. Maybe I can disable some home assistant entities to make the db smaller and include them in batches later? But how…?
edit2: well I managed to increase it to 512M, but still I get the disconnect… I think that is way beyond any database on a RPi could handle…
well the querry is defined by HA - is there a way to reduce the amout of data that my existing HA is writing to the db?
not enough space can ruled out (df -h shows 3.6T available) and permissions I think are also correct. At least MariaDB could create that database and write the table-files each containing a few K of data
well I did revisit this problem. During that time I used the mariadb addon which works perfect. I entered interactive docker mode to look for the settings made there:
