Just upgraded to 0.40.0 in a hope to fix some problems. Many issues are resolved, but unfortunately I’m getting loaded up on MySQL errors (I moved to MySQL in the hopes that it would cope better than sqlite did)
It seems stuck in some kind of never ending loop of errors triggering errors, but here’s a subset of the log:
17-03-11 19:30:09 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/srv/hass/hass_venv/lib/python3.4/site-packages/pymysql/connections.py", line 912, in connect
**kwargs)
File "/usr/lib/python3.4/socket.py", line 509, in create_connection
raise err
File "/usr/lib/python3.4/socket.py", line 500, in create_connection
sock.connect(sa)
ConnectionRefusedError: [Errno 111] Connection refused
File "/home/hass/.homeassistant/deps/sqlalchemy/engine/base.py", line 2138, in _wrap_pool_connect
return fn()
File "/home/hass/.homeassistant/deps/sqlalchemy/pool.py", line 387, in connect
return _ConnectionFairy._checkout(self)
File "/home/hass/.homeassistant/deps/sqlalchemy/pool.py", line 766, in _checkout
fairy = _ConnectionRecord.checkout(pool)
File "/home/hass/.homeassistant/deps/sqlalchemy/pool.py", line 521, in checkout
rec.checkin()
File "/home/hass/.homeassistant/deps/sqlalchemy/util/langhelpers.py", line 60, in __exit__
compat.reraise(exc_type, exc_value, exc_tb)
File "/home/hass/.homeassistant/deps/sqlalchemy/util/compat.py", line 187, in reraise
raise value
File "/home/hass/.homeassistant/deps/sqlalchemy/pool.py", line 518, in checkout
dbapi_connection = rec.get_connection()
File "/home/hass/.homeassistant/deps/sqlalchemy/pool.py", line 607, in get_connection
self.__connect()
File "/home/hass/.homeassistant/deps/sqlalchemy/pool.py", line 651, in __connect
connection = pool._invoke_creator(self)
File "/home/hass/.homeassistant/deps/sqlalchemy/engine/strategies.py", line 105, in connect
return dialect.connect(*cargs, **cparams)
File "/home/hass/.homeassistant/deps/sqlalchemy/engine/default.py", line 393, in connect
return self.dbapi.connect(*cargs, **cparams)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/pymysql/__init__.py", line 90, in Connect
return Connection(*args, **kwargs)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/pymysql/connections.py", line 699, in __init__
self.connect()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/pymysql/connections.py", line 959, in connect
raise exc
pymysql.err.OperationalError: (2003, "Can't connect to MySQL server on '172.16.1.122' ([Errno 111] Connection refused)")
File "/usr/lib/python3.4/asyncio/tasks.py", line 233, in _step
result = coro.throw(exc)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 359, in async_process_entity
new_entity, self, update_before_add=update_before_add
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 213, in async_add_entity
yield from entity.async_added_to_hass()
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/sensor/template.py", line 97, in async_added_to_hass
state = yield from async_get_last_state(self.hass, self.entity_id)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/restore_state.py", line 80, in async_get_last_state
None, _load_restore_cache, hass)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/helpers/restore_state.py", line 30, in _load_restore_cache
last_run = last_recorder_run(hass)
File "/srv/hass/hass_venv/lib/python3.4/site-packages/homeassistant/components/history.py", line 44, in last_recorder_run
.order_by(RecorderRuns.end.desc()).first())
File "/home/hass/.homeassistant/deps/sqlalchemy/orm/query.py", line 2690, in first
ret = list(self[0:1])
File "/home/hass/.homeassistant/deps/sqlalchemy/orm/query.py", line 2482, in __getitem__
return list(res)
File "/home/hass/.homeassistant/deps/sqlalchemy/orm/query.py", line 2790, in __iter__
return self._execute_and_instances(context)
File "/home/hass/.homeassistant/deps/sqlalchemy/orm/query.py", line 2811, in _execute_and_instances
close_with_result=True)
File "/home/hass/.homeassistant/deps/sqlalchemy/orm/query.py", line 2820, in _get_bind_args
**kw
File "/home/hass/.homeassistant/deps/sqlalchemy/orm/query.py", line 2802, in _connection_from_session
conn = self.session.connection(**kw)
File "/home/hass/.homeassistant/deps/sqlalchemy/orm/session.py", line 966, in connection
execution_options=execution_options)
File "/home/hass/.homeassistant/deps/sqlalchemy/orm/session.py", line 971, in _connection_for_bind
engine, execution_options)
File "/home/hass/.homeassistant/deps/sqlalchemy/orm/session.py", line 403, in _connection_for_bind
conn = bind.contextual_connect()
File "/home/hass/.homeassistant/deps/sqlalchemy/engine/base.py", line 2103, in contextual_connect
self._wrap_pool_connect(self.pool.connect, None),
File "/home/hass/.homeassistant/deps/sqlalchemy/engine/base.py", line 2142, in _wrap_pool_connect
e, dialect, self)
File "/home/hass/.homeassistant/deps/sqlalchemy/engine/base.py", line 1456, in _handle_dbapi_exception_noconnection
exc_info
File "/home/hass/.homeassistant/deps/sqlalchemy/util/compat.py", line 203, in raise_from_cause
reraise(type(exception), exception, tb=exc_tb, cause=cause)
File "/home/hass/.homeassistant/deps/sqlalchemy/util/compat.py", line 186, in reraise
raise value.with_traceback(tb)
return fn()
rec.checkin()
raise value
self.__connect()
self.connect()
raise exc
sqlalchemy.exc.OperationalError: (pymysql.err.OperationalError) (2003, "Can't connect to MySQL server on '172.16.1.122' ([Errno 111] Connection refused)")
**kwargs)
raise err
sock.connect(sa)
return fn()
rec.checkin()
raise value
self.__connect()
self.connect()
raise exc
return list(res)
**kw
e, dialect, self)
exc_info
return fn()
rec.checkin()
raise value
self.__connect()
self.connect()
raise exc
**kwargs)
raise err
sock.connect(sa)
return fn()
rec.checkin()
raise value
self.__connect()
self.connect()
raise exc
return list(res)
**kw
e, dialect, self)
exc_info
return fn()
rec.checkin()
raise value
self.__connect()
self.connect()
raise exc
17-03-11 19:30:09 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: (pymysql.err.OperationalError) (2003, "Can't connect to MySQL server on '172.16.1.122' ([Errno 111] Connection refused)")
