Hello, I am having trouble getting a MySQL tunnel for recorder to start automatically on hassio at startup. I have tried running the shell script (below) from within hassio on a startup event and as a shell script that runs every minute but recorder still fails to connect to the db.
Here is the bash script:
#!/bin/bash
exec >> $0.log 2>&1
dt=$(date '+%d/%m/%Y %H:%M:%S');
createTunnel() {
/usr/bin/ssh -i /config/ssh/id_rsa -4 -N -L 3307:localhost:3306 [email protected] &
if [[ $? -eq 0 ]]; then
echo $dt tunnel created successfully
else
echo $dt an error occurred creating a tunnel. ReturnCode is $?
fi
/bin/pidof ssh
if [[ $? -ne 0 ]]; then
echo $dt creating new tunnel ...
[ ! -f /root/.ssh/known_hosts ] && cp /config/ssh/known_hosts /root/.ssh/known_hosts
createTunnel
else
echo $dt tunnel up
fi
Please forgive me for not giving credit to the person who created the base of this script. I forget where I got it from.
My current success after a power cycle or reboot is that I have to ssh in, run the script, then restart hassio. That is the only way recorder reconnects to mysql correctly.
Can anyone help me run this script before HA starts so recorder does the right thing? Ideally, I would like to run the script continuously so that if the MySQL host goes down then the tunnel continues to try to connect.
Thanks!
