myUplink - change fan speed
Hello.
First post. The heating season is about to start in Sweden and I have problems lighting my wood-burning stove in the house when there is an exhaust air heat pump (Nibe F750). I therefore thought I would try to lower the fan when I light the wood-burning stove. myUplink is installed and seems to work. I have found a sensor called “Current fan mode” and I can see that the value changes when I change it in the myUplink app. In the devs documentation I see that there is a parameter called “sh-ventMode” which should be able to change the value of the fan - but I can’t find anything in HA to create an automation with. Anyone got a solution?
I assume you are using this:
Yhere is a section on known limitations that could perhaps help.
