I’ve had the NibeUplink working well for a few years but the recent switch to MyUplink is causing problems, besides the lack of interesting entities etc.
This chart shows my hot water temps, but as you can see the integration spends more time ‘unavailable’ than displaying data. In the MyUplink app however the data is consistently available, without issue, so I’m at a bit of a loss as to why HA report the data so poorly since it’s clearly leaving the ASHP and making it’s way to the internet?
I would think so. Again referring to your graph and you mentioned the app doesn’t lose data. So something in between your SMO and pi or pi to HA is not reporting consistently.
I have an s-series pump and it’s directly connected via Ethernet. It has been relatively stable with the occasional restart of the pump as sometimes the communication between it and HA hangs. But that is occasionally.
