myUSPS and myUPS Sensor Issue (in 0.42.4)
Hi all!
Configuration
  • Raspberry Pi 3
  • Latest Raspbian, non-Noobs install.
  • AiO install, originally 0.41.x, recently upgraded to 0.42.4 via “manual method”.
  • Usernames and Passwords are tested good. Opted in and there are packages on the dashboards of the websites.
  • Config stripped down for testing.
myUSPS Error
17-04-22 02:58:14 ERROR (MainThread) [homeassistant.setup] Not initializing sensor.usps because could not install dependency myusps==1.0.3
17-04-22 02:58:14 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.usps: Could not install all requirements.
17-04-22 02:58:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service_data=title=Invalid config, message=The following components and platforms could not be set up:
* sensor.usps
Please check your config, notification_id=invalid_config, service=create, service_call_id=1978466896-1>
* sensor.usps
Please check your config, notification_id=invalid_config, service=create, service_call_id=1978466896-2>
17-04-22 02:58:14 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=persistent_notification.invalid_config, new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up:
* sensor.usps
Please check your config; title=Invalid config @ 2017-04-21T21:58:14.800982-05:00>>
What I attempted so far
sudo apt-get install libxml2-dev
sudo apt-get install libxslt1-dev
sudo su -s /bin/bash homeassistant
source /srv/homeassistant/homeassistant_venv/bin/activate
pip3 install myusps
Which then spat back
Collecting myusps
Requirement already satisfied: requests==2.12.4 in /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages (from myusps)
Requirement already satisfied: bs4==0.0.1 in /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages (from myusps)
Requirement already satisfied: python-dateutil==2.6.0 in /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages (from myusps)
Requirement already satisfied: beautifulsoup4 in /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages (from bs4==0.0.1->myusps)
Requirement already satisfied: six>=1.5 in /srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages (from python-dateutil==2.6.0->myusps)
Installing collected packages: myusps
Successfully installed myusps-1.0.5
  • I have stripped my config down to bare bones (only auto discover stuff, and the working FedEx sensor, HTTP, and non-working UPS sensor.)
  • Rebooted.
myUPS Error
17-04-22 02:58:14 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.ups
17-04-22 02:58:15 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up platform ups
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/helpers/entity_component.py", line 153, in _async_setup_platform
    entity_platform.schedule_add_entities, discovery_info
  File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
    value = future.result()
  File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
    raise self._exception
  File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
  File "/srv/homeassistant/homeassistant_venv/lib/python3.4/site-packages/homeassistant/components/sensor/ups.py", line 44, in setup_platform
    import upsmychoice
  File "/home/homeassistant/.homeassistant/deps/upsmychoice/__init__.py", line 4, in <module>
    from json.decoder import JSONDecodeError
ImportError: cannot import name 'JSONDecodeError'
  • Not much, didn’t see much in Googling issues with the sensor, and haven’t dug into the error \ traceback text as I’m pretty not awesome at figuring those out.
Any thoughts or directions out there for me?
Did you get this figured out? im running into the same issues.
It’s partially resolved in .45. Still have to modify something manually. Putting something on my calendar to remind me to detail tomorrow.
Hi Jonathan, any updates on how to get this squared away? Thanks!
Nope! What I thought worked, immediately betrayed me and stopped working.
This thread is pretty active and I haven’t revisited it in a little bit. We might have better luck there: USPS Sensor 'myusps.USPSError: Not logged in'
