N00b First Time Sun Automation
Hello. First post, and apologies for what I assume is basic knowledge for the educated. I assume there are many topics on this already, but I am so new that I am not really sure what keywords to use or search for help.
I have an automation setup. I want to turn lights on based on the elevation of the sun. I have read some documents but keep getting confused. I built the automation and when I run the action I do get the intended outcome of the light turning on along with the feedback on the dashboard that my shelly relay is functioning.
I generated this YAML from the configuration editor but the automation did not execute. I fiddled with the elevation status to test new code multiple times but, it is still a no go.
Any help?
alias: Turn Front Lights on @ Dusk
description: ''
  - platform: state
    entity_id:
      - sun.sun
    attribute: elevation
    to: '-89'
condition: []
  - type: turn_on
    device_id: 6ce08099af5e1d5dcaadc0ab9dcacd7f
    entity_id: switch.outside_front_lights
    domain: switch
mode: single
The way you have the trigger the attribute has to change from exactly -4 to exactly -89. That can’t ever happen.
Ty for the reply. I still do not really get it though. I did change the code and this appears to work. I had to make two automations. One for on and one for off. Not sure if that is correct if they could be combined or not.
alias: Turn Front Lights Off @ Dawn
description: ''
  - platform: numeric_state
    entity_id: sun.sun
    below: '-89'
condition: []
  - type: turn_off
    entity_id: switch.entry_lights
    domain: switch
mode: single
and
description: ''
    entity_id: sun.sun
    below: '-4'
condition: []
  - type: turn_on
    domain: switch
mode: single
This appears to work, but there has to be a better way.
The time that it takes to go from -4 to -89 is constant, no? Why not just turn the lights on when the sun is at -4, then put a wait timer on it until the same time that -89 typically occurs?
I don’t know if it’s actually “better” or not but it’ll definitely be more complicated if you use the two triggers in one automation and then use a ‘choose’ in the action to decide if you want it to turn on or off.
    entity_id: sun.sun
    below: '-89'
    entity_id: sun.sun
    below: '-4'
  choose:
    - conditions:
        - {{ trigger.id == 'off' }}
      sequence:
        - service: switch.turn_off
    - conditions:
        - {{ trigger.id == 'on' }}
      sequence:
        - service: switch.turn_on
mode: single
I think it varies based on time of the year. I may be very wrong tho.
Ah, super simple to understand. I agree, perhaps its more complicated this way. Tradeoffs for sure.
