N00b question: After editing and saving a yaml, do I need to reinstall it to the device?
After editing and saving a yaml, do I need to reinstall it to the device, or does saving it do the trick?
You need to reinstall it. Think of the yaml as a set of instructions for creating the device firmware. The firmware needs to be compiled and then loaded onto the device.
if the device is already on your network, this is easy to do by wireless (OTA) :wink:
You must have the OTA option enabled in the original YAML though:
ota:
  password: "aaaabbbbccccdddeeefff"
Otherwise add it and upload the firmware manually (USB cable) and then you should be able to perform OTA updates after that.
