N00b zigbee question wrt bulbs
Q: do zigbee bulbs continue to work as extenders if they are off by switch and not by app?
Bulb in question: Philips Hue White 10.5W Equivalent 75W A19 Base E26 LED Smart Bulb, Dimmable, Bluetooth & Zigbee Compatible, Voice Activated with Alexa & Google Assistant, 4-Pack https://a.co/d/5RtGFHR
Context:
I have an aqara door sensor on my freezer with an automation to have all Alexas warn me if the door is open for more than 30s until the door closes. Effectively annoying. My HA sits in a server enclosure in the basement but it would be easy enough to create a mesh of bulbs if they repeat the signal even when off.
If the bulb gets power it will act as an extender. If your switch turns off the power to the bulb then it will not.
-David
