For the last couple of days I’ve gotten an error if I ask Google to ‘Synchronize devices’, it complains about nabu casa. I’ve tried logging out of nabu casa and back in,
Is there a problem at the moment?
As an experiment with a similar issue I’ve been having, remove climate and lights with color entities.
I had this issue with both Nabu Casa and the DIY Google Assistant Integration.
Update: My DIY Google Assistant started allowing Climate and RGB Light entities.
Not sure if something magically repaired itself in the cloud.
There is definetely something wrong. I’ve gone and tried to create a new home. And I’ve gotten the IKEA hub attached, as well as a few more items, but when I try to attach nabu casa I get an error.
Translated from danish it says ‘the connection could not be updated, check your connection.’
Since you’re a paying member reach out to support.
We didn’t solve my Google Home issue but I can’t say I was 100% engaged with solving it.
I was about to submit a bug report last night but then I noticed it’s working fine for me now.
Keep us updated I’m curious what is wrong with your system as it might be affecting me intermittently as well.
Ok, I got it solved by deselecting every device from the google integration, but having the integration active.
Then add it to google home.
Then activating each individual item back into the google integration.
Now it works again.
Yea that sounds like the issue I had. But when I re-added climate and RGB devices it broke again.
Now all seems to be well for me as well.
Best of luck.
