HarvsG
January 4, 2022, 8:12pm
1
Is there any plan to use the new Google Assistant local fulfilment SDK?
It would enable faster responses and a little less data going to google
According to balloob , it should be already included
See here , but I don’t see it in my logbook…
opened 04:12PM - 08 Dec 21 UTC
As discussed @ https://community.home-assistant.io/t/alexa-home-assistant-skill-… slow-timing-out/321257 I am not alone experiencing this, which should rule out some esoteric issue native to just my setup/isp/etc. The issue in summary is that I ask voice assistant to do something and then voice assistant will say it failed, but the requested action happens anyway. My network although not fastest, is rock-solid latency wise (household partakes in online gaming and we'd notice any disconnects or high latency straight away),
With Alexa she will take longer than usual, then say '"Device name" is not responding check its internet connectivity' or something like that, and usually while she is saying this whatever I asked triggers and starts happening 8 times out of ten, 2 times it just fails altogether. As mentioned in the thread you can often see ha devices go "offline" in the Alexa app and then come back "online" when refreshed.
To me it looked like communication between amazon and nabu.casa is timing out. I ordered and set up Google Home Mini to check if non-amazon device will have same problem, and sadly it has exactly same issue.
With Google Home she will take longer than usual and then say 'Sorry, I couldn't reach the Home Assistant Cloud by Nabu Casa.' or 'Sorry, it looks like the Home Assistant Cloud by Nabu Casa is unavailable right now.' and then like 2 times out 10 it will happen regardless, but definitely will actually fail more often than Alexa does.
I tried changing APs, changing from 5GHz to 2.4GHz wifi, closer to AP, nothing helps. I have 35 devices/scripts/sensors exposed to both Alexa and Google Home, is that too much? This wasn't always happening, but it's hard to pinpoint exactly when it started, it sort of creeped up, happened once a month, then once a week, once a day and nowadays it's few times a day.
What’s also strange, nabucasa users are complaining about the big delay, if the local system is already active, how come we are still notificating the delay?
This issue :
HarvsG
January 14, 2022, 2:10pm
5
And do we have to enable it in the UI?
i have it enabled, doesnt make local working
