Using the remote UI through Nabu Case for a while and worked perfectly till recently I noticed the UI not being available at times. Still searching what the cause could be and I need some help with this error:
2019-10-02 07:24:42 ERROR (MainThread) [hass_nabucasa.remote] Can't handle request-connection without backend
2019-10-02 07:24:42 ERROR (MainThread) [hass_nabucasa.iot] Error handling message
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/iot.py", line 220, in _handle_connection
self.cloud, msg["handler"], msg["payload"]
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/iot.py", line 274, in async_handle_message
return await handler(cloud, payload)
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/iot.py", line 309, in async_handle_remote_sni
await cloud.remote.handle_connection_requests(caller_ip)
File "/usr/local/lib/python3.7/site-packages/hass_nabucasa/remote.py", line 216, in handle_connection_requests
raise RemoteNotConnected()
hass_nabucasa.remote.RemoteNotConnected
2019-10-02 07:42:08 ERROR (MainThread) [metno] https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/1.9/ returned Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None [Try again]
2019-10-02 07:42:08 ERROR (MainThread) [homeassistant.components.met.weather] Retrying in 17 minutes
2019-10-02 09:33:02 ERROR (MainThread) [hass_nabucasa.remote] Can't handle request-connection without backend
2019-10-02 09:33:02 ERROR (MainThread) [hass_nabucasa.iot] Error handling message
I too have issued often with nabucasa, can’t load my webpage… Still works on my public IP with port forwarding…
So when in am logged in with ip instead of nabucasa… I still see the service as connected, also when I do a disconnect / connect , still doesn’t work…
It’s only browsing that doesn’t work, other cloud API still work with nabucasa, like Google assistant.
I need to restart hassio completely to restore it…
I think I solved my issue. I have scheduled a network interface reset once a week and since then all keeps working fine. I think that for some reason my WiFi was disconnecting and not reconnecting anymore.
For me all seems to work fine now.
I migrated from my RaspberryPI to docker and since then all my issues are gone.
I don’t need to restart my network interface anymore.
No more issues with remote UI.
Started getting this issue after 103. Sometimes it works sometimes not. Have been in touch with Nabu Casa support but no solution yet. Have given up and setup my own domain for my ha instead
Custom Components: Wyze Sense, Custom Header, and Lovelace Swipe Navigation, each installed via HACS.
Although it seems to now be resolved after another HA restart.
I only recently moved from a Docker install to HassIO in a VM (on my unRaid server). Its possible that could have something to do with it.
Same here, HassOS VM. Since that reboot of the VM, the issue has not come back. Makes me wonder if it was a temporary “me” problem. Could have just been a blip in connectivity.
