Nabu casa simple webhooks issue
I’m trying to create a very simple webhook, but without success.
I’ve checked the various points, but I can’t find the issue — and if it’s a problem between the chair and the keyboard, I can’t solve it on my own :slightly_smiling_face:
I’m on Nabu Casa, so everything is almost automatic:
I created my automation with the webhook trigger.
I unchecked “only accessible from the local network.”
I kept only “POST” and “PUT” or “POST” alone in the config (but I also tried all the other combinations: GET, PUT).
I do have an action following the trigger.
I did enable the webhook in Settings → Home Assistant Cloud → Webhook.
I’m retrieving the link directly from the automation; the link is already formatted with the Nabu Casa URL and the webhook ID:
https://xxxxxxx.ui.nabu.casa/api/webhook/-iOZK-RDhny0xKKSjWiK18F_B
I systematically get an HTTP 405 error.
I also tried the URL shown in the Home Assistant Cloud section (in Settings):
https://hooks.nabu.casa/gAAAAABoyxxxxxxxxxxx
and there I get an “invalid response” error.
I tried on both Chrome and Edge.
My Nabu Casa itself works perfectly; I have no access problems and everything is correctly enabled in the config.
Thanks in advance for any help!
Chrisbati
405 error indicates you’re calling the page with an HTTP method that it isn’t authorized to do. If you’re trying in your browser, that’s a GET request.
