I am trying to login with my URL (http://hassio.xxxxxxx.xxx) that points at NabuCasas remote-control URL. It is not possible to register application and complaining over “mobile_app” integration that is not enabled. I am using “default_config:”, I have also try to manual add “mobile_app:” but no difference…
If I do the same inside my LAN (WiFi) and with my ip-number to hassio, everything works. Also mobile_app registration works.
If I use a web-browser outside LAN with my URL (http://hassio.xxx) I can connect to hassio without problem.
No error inside my logs, what I can see, related to mobile_app or something that happens when I try to connect with mobile app.
In configuration.yaml and “base_url:”, I have set my http://hassio.xxxxxxxxx.xxx address now, is this maybe a problem ? Should I use my NabuCasa remote control address or something else ?
I have not configure SSL-related things on my hassio…
My mobile-phone is a Samsung S10 and updated.
I am running a docker on Ubuntu 18.04.2 LTS. Latest version of home-assistant.
System Health
arch | x86_64 |
dev | false |
docker | true |
hassio | true |
os_name | Linux |
python_version | 3.7.6 |
timezone | Europe/Stockholm |
version | 0.104.3 |
virtualenv | false |
Lovelace
mode | storage |
resources | 0 |
views | 15 |
