I would like a sensor to be able to change its name depending on its status, for example, if 3 kWh of electricity has been consumed, the sensor would be called “Consumption” and if, on the other hand, that same sensor becomes negative due to injection into the grid - 3 kWh then It would be called “Injected”
I hope I have explained myself, thank you
You may have to be more specific about the context in which you’d like this to happen. If mean on an entity card in a dashboard, for instance, they allow you to change the display name. You could have a conditional card chose between two entity cards with different values for name
depending on if the sensor is below zero.
