Name of triggered Device in notification
Hi all,
I’m trying to make a simple automation that tells me when my sensor batteries are low. The idea is that the message would have the sensor name in it so I can have one automation with multiple triggers.
I have found what I thought would work which is to add this template to the message text:
“message”: “Battery is Low in one of the sensors: {{ trigger.to_state.attributes.friendly_name }}”
But no matter what I’ve tried, I always get this error when the automation is triggered:
NOTE: the trigger is a binary_sensor defined in my configuration file and the states are set by MQTT.
homeassistant.exceptions.TemplateError: UndefinedError: ‘trigger’ is undefined
How is trigger “undefined” if the automation was triggered?
I’ve looked through other posts and haven’t found a clear answer. Is there any other way to capture the trigger name?
Um… crystal ball time or post your automation??
of course after many tries, and then right after posting this it starts to work.
I’m thinking I wasn’t reloading the atomations like I thought at first because I was at first using the GUI (configuration -> automations) to create the automation. Then I went into the automation.yaml file to change data to data_template.
Yeah if you edit via yaml you need to reload automations to activate them…
I thought I had, but apparently not. Thanks for answering so quickly.
And sorry I didn’t put the whole automation text, It’s not formatting correctly when i try to paste it in here.
Just a note, I did have to change the template part to:
{{ trigger.to_state.name }}” because of the attributes.friendly_name returned a blank.
For future reference you can use the instructions for posting code (at the top of the forum) or if you use 3 backticks on the first line and then 3 backticks after the last line of the code it should post properly. ` next to 1 on keyboard…
Glad you got it sorted…
