Ive searched the forum but cannot find someone with the same problem. Im trying to rename the zwave devices ive added. I use AeoTec Z-Wave stick.
I did test this:
Configuration - Z-Wave - Picked a node - Renamed the node and saved.
After this i did reboot HA. Now the node is renamed under the Z-Wave menu.
In the UI it still have the same name, so I did rename it there by clicking the device and the settings, and did rename. Now in the UI it does have the new name.
But still it does not get this name under states menu. I have rebooted HA atleast 10 times (Cause of other things).
I just rename the entity_registry.yaml file to entity_registry.yaml.old then restart hass. it will then rebuild the entity_registry file from the node names in the xml file on the z stick.
That way I don’t have to go thru and rename every node once I rename it in z wave.
