This template (and others very similar) was working perfectly but now they give an error:
Error rendering template: UndefinedError: 'count_pir' is undefined
Can anyone help?
{% set ns = namespace(count_pir) %}
{%- set ns.count = 0 %}
{%- for pir in states.binary_sensor -%}
{% set type = pir.name.split(' ') | first -%}
{% if type == 'PIR' and
pir.state == 'on' %}
{%- set ns.count = ns.count + 1 -%}
- {{ pir.name[4:] }}
{% endif -%}
{% endfor %}
{%- if ns.count == 0 -%}
- None detected -
{%- endif %}
As background, most of these templates are used to generate the message part of a Telegram notifications but that isn’t really relevant. All my sensors have standard names and in this case they are of the form:
name: PIR room_name
EDIT: Ok, yes it does work, but only if I put {% set ns = namespace(count_pir = 0) %}
Now, I’m still a beginner with Python so clearly I don’t fully understand what is going on here but whatever the case, it doesn’t explain why it suddenly stopped working.
When you call the method namespace with count_pir=0 inside it, it creates the namespace with count_pir=0. Then you add count to it later on. You can just skip all that and create it with count.
{% set ns = namespace(count=0) %}
You can get the same outcome with this code (which you essentially had
{% set ns = namespace() %}
{% set ns.count = 0 %}
So that should have worked for you with the count_pir not set to anything because the method just ignores that input.
EDIT: I just noticed this line in your post. That’s basically saying that count_pir isn’t defined in the scope. Meaning that there is no variable count_pir to pull from. So when you change it to count_pir=0, you’re giving the function a keyword argument, count_pir.
This is a timely post! I recently tried to create the same functionality (a counter within a for-loop) but was thwarted by tighter scoping rules in Jinja2 version 2.10.
The suggested solution was to create the counter variable using a namespace (as shown above). However, when I tried it in the Template Editor, it failed. I concluded Home Assistant’s implementation of Jinja2 does not support namespaces. The following post seemed to confirm my conclusion (it’s an old post, so it’s an old version of Home Assistant):
However, this thread shows it does work. Therefore it must be due to the fact I’m using version 0.80. I loaded a docker instance of 0.86.4, tried the same experiment, and the Template Editor correctly evaluated my for-loop example containing a namespace.
Yeah, it must have been added at some point because I know it never worked in the past. namespace that is. But now it’s working for me in the template editor. On 87.
Thanks. From a bit of reading and the reply from @petro I think I might have got my head around how namespace works now…
@123 I have been using this (in the form from my original post) for some time now, several months I’d guess form about Oct/Nov 2018 and it worked perfectly until (I noticed in) 0.88.1.
I can only assume that as you say, something underlying was upgraded and so stopped it working.
I’d like to know though, should I have known this from reading the upgrade notes and breaking changes? Because it seems to me that whilst I have no complaints with the underlying software being upgraded it would be nice to be told that it might have an impact.
