I’ve read the Jinja docs but … I misunderstand how the use of namespace(var=val), or may be it’s the scope.
The assignment ’ set ns = namespace(…’ is OK, no error
But when trying to use in -service:rest_command, the error ‘ns undefined’ raise !
What I want to do is :
set/define a variable and be able to use it later, in another service (same trigger …)
How to do that ?
I guess I also misunderstand the ‘embebdment’ and interactions of/between differents items like service: , action: …
Any ‘for the noob’ docs on this subject ? Thanks for a link I would be able to understand …
alias: 'rhasspy SetLight'
platform: event
event_type: rhasspy_SetLight
#event_data:
# piece2: piece
- service_template: >
{% set action = trigger.event.data.action %}
{% set niveau = trigger.event.data.niveau %}
{% set ns=namespace(test="test") %}
{% if action == 'allume' %}
light.turn_on
{% elif action == 'éteint' %}
light.turn_off
{% else %}
chabada
{% endif %}
data_template:
entity_id: light.bureau
- service: rest_command.tts
data_template:
payload: >
{% set piece = trigger.event.data.piece %}
j'{{action}} la lumière de {{piece}} et {{ns.test}}
As far as I know you can’t use a variable from one template in another template even if it is in the same automation, you can only use it in the same template. I think the namespaces are for inside the same template.
@Burningstone is correct. There is zero way for a variable to leave a template without a custom integration, or writing it to something else (i.e. an input_number). The namespace is if you want the variable to leave the current scope. i.e. inside of an if block or for loop.
If what you posted is something you want to do, you could achieve it with a script. Those parameters passed in are available for the whole script.
script:
rhasspy_setlight_script:
# my_input is a 2 part variable separated by comma.
# Part 1 is the service
# part 2 is the other data...
sequence:
- service_template: {{ my_input.split(',')[0] }}
data_template:
entity_id: {{ entity_id }}
- service_template: rest_command.tts
data_template:
payload: "The variable was {{ my_input.split(',')[1] }}"
Then just call your script in the automation.
platform: event
#event_data:
# piece2: piece
- service: script.rhasspy_setlight_script
data_template:
# Create a value with "service_name, value"
my_input: >
{% set ns=namespace(action="action", test="test") %}
{% set ns.action="light.turn_on" %}
{% set ns.action="light.turn_off" %}
{% else %}
{% set ns.action="chabada" %}
{% endif %}
{{ ns.action ~ "," ~ ns.test }}
It’s a little hacky…but it should work. It seems better than creating an input_text to store values for us.
Whereas a variable used within a for-loop has its scope limited to the for-loop (and represents a use-case for namespace), there’s no such constraint for if-else.
Ok, I now see you just copy-pasted the original code. FWIW, the use of namespace is unnecessary in this situation.
Yeah, my example, there is zero reason to use namespace. Though I guess I didn’t realize variable scope would persist outside of the if statement. Too used to c/c++. So I learned something there!
The only reason you would maybe do something like I did is if you’ve set up an elaborate template with macros and what not to parse something and you want to preserve multiple outputs of that template for other tasks. Otherwise, just create a new script data variable for each thing.
But I feel like if this is your design, there’s probably a different approach you can use to do what you’re trying to do
The idea behind a namespace/global variable was to be able use it in differents services/actions …
(in my example, I used 1°) service_template and then 2°) service:rest_command.
I wanted to ‘share’ variables between these 2 services.)
But I guess they are other way to achieve this, that I still have to discover.
