Hello.
I am trying to set up a dashboard for my athom homey.
But i cant figures out why my namron dimmers don’t work… https://www.elektroimportoren.no/namron-led-dimmer-z-wave-200w/1402756/Product.html
Are they not supported some how?
Hello.
Thank you for the reply.
So your Namron is called ecodim i homeassistant?
Is this something you have added in home assistant?
not need anything extra
This was the reason I started using Z Wave Js to MQTT, yes this is called i HA .
ECO-DIM Z-Wave Led dimmer (ECO-DIM) av EcoDim
So you have exactly the dimmers i have?
Could you please explain what you mean by “i use zwavejs-server”? Have you installed zwavejs?
U don’t think i can do that when i use unraid an run home assistant as a VM
Hmm, but then i need to have a z Wave stick right?
Today i use athom homey with mqtt
