Namron Zigbee 2 channel switch - Incorrect reporting
I’m adding the “Namron Zigbee 2 channel switch K4” but it’s not reporting the actual buttons. It got 4 button’s, 2on and 2off buttons.
The only reporting items I can see is battery status and Identity check.
Is there any way I can make add the device to the common drivers?
Adding the JSON “debug” as well:
“data”: {
“ieee”: “REDACTED”,
“nwk”: 11020,
“manufacturer”: “NAMRON AS”,
“model”: “4512729”,
“name”: “NAMRON AS 4512729”,
“quirk_applied”: false,
“quirk_class”: “zigpy.device.Device”,
“quirk_id”: null,
“manufacturer_code”: 4644,
“power_source”: “Battery or Unknown”,
“lqi”: 136,
“rssi”: -66,
“last_seen”: “2023-11-25T23:44:36”,
“available”: true,
“device_type”: “EndDevice”,
“signature”: {
“node_descriptor”: “NodeDescriptor(logical_type=<LogicalType.EndDevice: 2>, complex_descriptor_available=0, user_descriptor_available=0, reserved=0, aps_flags=0, frequency_band=<FrequencyBand.Freq2400MHz: 8>, mac_capability_flags=<MACCapabilityFlags.AllocateAddress: 128>, manufacturer_code=4644, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=<DescriptorCapability.NONE: 0>, *allocate_address=True, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=True, *is_full_function_device=False, *is_mains_powered=False, *is_receiver_on_when_idle=False, *is_router=False, *is_security_capable=False)”,
“endpoints”: {
“1”: {
“profile_id”: “0x0104”,
“device_type”: “0x0001”,
“input_clusters”: [
“0x0000”,
“0x0001”,
“0x0003”,
“0x0b05”,
“0x1000”
“output_clusters”: [
“0x0003”,
“0x0004”,
“0x0005”,
“0x0006”,
“0x0008”,
“0x0019”,
“0x0300”,
“0x1000”
“2”: {
“input_clusters”: [
“0x0000”,
“0x0001”,
“0x0003”,
“0x0b05”,
“0x1000”
“0x0003”,
“0x0004”,
“0x0005”,
“0x0006”,
“0x0008”,
“0x0019”,
“0x0300”,
“0x1000”
“model”: “4512729”
“active_coordinator”: false,
“entities”: [
“entity_id”: “button.namron_as_4512729_identify”,
“entity_id”: “sensor.namron_as_4512729_battery”,
“entity_id”: “sensor.namron_as_4512729_battery_2”,
“neighbors”: ,
“routes”: ,
“endpoint_names”: [
“name”: “LEVEL_CONTROL_SWITCH”
“user_given_name”: null,
“device_reg_id”: “4db6d44ab0dfca002938f310135b9cf8”,
“area_id”: “spisestue”,
“cluster_details”: {
“1”: {
“device_type”: {
“name”: “LEVEL_CONTROL_SWITCH”,
“id”: 1
“profile_id”: 260,
“in_clusters”: {
“0x0000”: {
“endpoint_attribute”: “basic”,
“attributes”: {
“0x0004”: {
“attribute_name”: “manufacturer”,
“value”: “NAMRON AS”
“0x0005”: {
“attribute_name”: “model”,
“value”: “4512729”
“unsupported_attributes”: {}
“0x0001”: {
“endpoint_attribute”: “power”,
“attributes”: {
“0x0021”: {
“attribute_name”: “battery_percentage_remaining”,
“value”: 200
“0x0033”: {
“attribute_name”: “battery_quantity”,
“value”: 0
“0x0031”: {
“attribute_name”: “battery_size”,
“value”: 255
“0x0020”: {
“attribute_name”: “battery_voltage”,
“value”: 33
“0x0003”: {
“endpoint_attribute”: “identify”,
“attributes”: {},
“0x0b05”: {
“endpoint_attribute”: “diagnostic”,
“attributes”: {},
“0x1000”: {
“endpoint_attribute”: “lightlink”,
“attributes”: {},
“out_clusters”: {
“0x0003”: {
“attributes”: {},
“0x0004”: {
“endpoint_attribute”: “groups”,
“attributes”: {},
“0x0005”: {
“endpoint_attribute”: “scenes”,
“attributes”: {},
“0x0006”: {
“endpoint_attribute”: “on_off”,
“attributes”: {},
“0x0008”: {
“endpoint_attribute”: “level”,
“attributes”: {},
“0x0019”: {
“endpoint_attribute”: “ota”,
“attributes”: {},
“0x0300”: {
“endpoint_attribute”: “light_color”,
“attributes”: {},
“0x1000”: {
“attributes”: {},
“2”: {
“device_type”: {
“id”: 1
“profile_id”: 260,
“in_clusters”: {
“0x0000”: {
“attributes”: {},
“0x0001”: {
“attributes”: {
“0x0021”: {
“value”: 200
“0x0033”: {
“value”: 0
“0x0031”: {
“value”: 255
“0x0020”: {
“value”: 33
“0x0003”: {
“attributes”: {},
“0x0b05”: {
“attributes”: {},
“0x1000”: {
“attributes”: {},
“out_clusters”: {
“0x0003”: {
“attributes”: {},
“0x0004”: {
“attributes”: {},
“0x0005”: {
“attributes”: {},
“0x0006”: {
“attributes”: {},
“0x0008”: {
“attributes”: {},
“0x0019”: {
“attributes”: {},
“0x0300”: {
“attributes”: {},
“0x1000”: {
“attributes”: {},
