Namron ZigBee RGB Fjernkontroll
A simple blueprint for the Namron ZigBee RGB Fjernkontroll
blueprint:
  name: ZHA - Namron Fjernkontroll
  description: |
    Control lights with an Namron remote
  domain: automation
  input:
    remote:
      description: Namron remote to use
      selector:
        device:
          integration: zha
          manufacturer: NAMRON AS
          model: "4512706"
    light_1:
      description: The light(s) to control
      selector:
          entity:
            domain: light
    light_2:
      selector:
          entity:
            domain: light
    light_3:
      selector:
          entity:
            domain: light
    light_4:
      selector:
          entity:
            domain: light
    scene_1:
      description: Action to run on short press on the S1 button
      default: []
      selector:
    scene_2:
      description: Action to run on short press on the S2 button
      default: []
      selector:
    scene_3:
      description: Action to run on short press on the S3 button
      default: []
      selector:
    scene_4:
      description: Action to run on short press on the S4 button
      default: []
      selector:
    scene_5:
      description: Action to run on short press on the S5 button
      default: []
      selector:
    scene_6:
      description: Action to run on short press on the S6 button
      default: []
      selector:
    scene_7:
      description: Action to run on short press on the S7 button
      default: []
      selector:
mode: parallel
max_exceeded: silent
  - platform: event
    event_type: zha_event
    event_data:
      device_id: !input remote
  - variables:
      command: "{{ trigger.event.data.command }}"
      cluster_id: "{{ trigger.event.data.cluster_id }}"
      endpoint_id: "{{ trigger.event.data.endpoint_id }}"
      args: "{{ trigger.event.data.args }}"
      step_mode: "{{ trigger.event.data.params.step_mode }}"
      step_size: "{{ trigger.event.data.params.step_size }}"
      transition_time: "{{ trigger.event.data.params.transition_time }}"
      hue: "{{ trigger.event.data.params.hue }}"
      color_temp_mireds: "{{ trigger.event.data.params.color_temp_mireds }}"
      scene_id: "{{ trigger.event.data.params.scene_id }}"
#--------------scenes------------------------------------------
  - choose:
      - conditions:
          - "{{ command == 'recall' }}"
          - "{{ cluster_id == 5 }}"
          - "{{ scene_id == 1 }}"
        sequence: !input scene_1
#          - "{{ '!input scene_' ~ scene_id }}"
      - conditions:
          - "{{ scene_id == 2 }}"
        sequence: !input scene_2
      - conditions:
          - "{{ scene_id == 3 }}"
        sequence: !input scene_3
      - conditions:
          - "{{ scene_id == 4 }}"
        sequence: !input scene_4
      - conditions:
          - "{{ scene_id == 5 }}"
        sequence: !input scene_5
      - conditions:
          - "{{ scene_id == 6 }}"
        sequence: !input scene_6
      - conditions:
          - "{{ scene_id == 7 }}"
        sequence: !input scene_7
#------------------1---------------------
      - conditions:
          - "{{ command == 'on' }}"
          - "{{ cluster_id == 6 }}"
          - "{{ endpoint_id == 1 }}"
          - "{{ args == [] }}"
        sequence:
          - service: light.turn_on
            target: !input light_1
      - conditions:
          - "{{ command == 'off' }}"
        sequence:
          - service: light.turn_off
      - conditions:
          - "{{ command == 'step_with_on_off' }}"
          - "{{ cluster_id == 8 }}"
          - "{{ step_mode == 'StepMode.Up' }}"
        sequence:
              brightness_step: 32
      - conditions:
          - "{{ step_mode == 'StepMode.Down' }}"
        sequence:
              brightness_step: -32
      - conditions:
          - "{{ command == 'move_to_hue' }}"
          - "{{ cluster_id == 768 }}"
        sequence:
              hs_color: ["{{ 360/250*hue }}",100]
      - conditions:
          - "{{ command == 'move_to_color_temp' }}"
        sequence:
              color_temp: "{{ color_temp_mireds }}"
      - conditions:
          - "{{ command == 'step_color_temp' }}"
        sequence:
              color_temp: 153
      - conditions:
        sequence:
              color_temp: 500
#-----------------2---------------------------------------
      - conditions:
          - "{{ endpoint_id == 2 }}"
        sequence:
            target: !input light_2
      - conditions:
        sequence:
      - conditions:
        sequence:
              brightness_step: 32
      - conditions:
        sequence:
      - conditions:
        sequence:
      - conditions:
        sequence:
      - conditions:
        sequence:
              color_temp: 153
      - conditions:
        sequence:
              color_temp: 500
#------------------3--------------------------------------
      - conditions:
          - "{{ endpoint_id == 3 }}"
        sequence:
            target: !input light_3
      - conditions:
        sequence:
      - conditions:
        sequence:
              brightness_step: 32
      - conditions:
        sequence:
      - conditions:
        sequence:
      - conditions:
        sequence:
      - conditions:
        sequence:
              color_temp: 153
      - conditions:
        sequence:
              color_temp: 500
#---------------------4-----------------------------------
      - conditions:
          - "{{ endpoint_id == 4 }}"
        sequence:
            target: !input light_4
      - conditions:
        sequence:
      - conditions:
        sequence:
              brightness_step: 32
      - conditions:
        sequence:
      - conditions:
        sequence:
      - conditions:
        sequence:
      - conditions:
        sequence:
              color_temp: 153
      - conditions:
        sequence:
              color_temp: 500
