I’m trying to link Nanoleaf Elements to Home Assistant 2022.4.7 running on a Raspberrry Pi. Whenever I try and add either set of Elements, I get a Failed To Connect error:
I’ve been struggling because most help posts re: nanoleaf are quite old and reference solutions not currently in the documentation (one involves manual config and tokens, but the manual config in the current documentation is about adding the integration manually)
I found a similar sounding bug here. so I added the folder from that thread to my config folder but no joy.
I can connect to the Elements using the Nanoleaf Android app fine.
It’s worth mentioning I’m not particularly competent - HA is by far the most complex IT system I’ve had to engage with for over a decade.
Logs!
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 95, in create_connection
raise err
File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 85, in create_connection
sock.connect(sa)
OSError: [Errno 101] Network unreachable
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 398, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 239, in request
super(HTTPConnection, self).request(method, url, body=body, headers=headers)
File "/usr/local/lib/python3.9/http/client.py", line 1285, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/usr/local/lib/python3.9/http/client.py", line 1331, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.9/http/client.py", line 1280, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/usr/local/lib/python3.9/http/client.py", line 1040, in _send_output
self.send(msg)
File "/usr/local/lib/python3.9/http/client.py", line 980, in send
self.connect()
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 205, in connect
conn = self._new_conn()
File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f8a59dd60>: Failed to establish a new connection: [Errno 101] Network unreachable
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 440, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 785, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.68.107', port=80): Max retries exceeded with url: /app (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f8a59dd60>: Failed to establish a new connection: [Errno 101] Network unreachable'))
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 249, in _async_setup_platform
await asyncio.shield(task)
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/config/custom_components/tapo_p100_control/switch.py", line 44, in setup_platform
add_entities([P100Plug(p100)])
File "/config/custom_components/tapo_p100_control/switch.py", line 53, in __init__
self.update()
File "/config/custom_components/tapo_p100_control/switch.py", line 83, in update
self._p100.handshake()
File "/usr/local/lib/python3.9/site-packages/PyP100/PyP100.py", line 122, in handshake
r = self.session.post(URL, json=Payload, timeout=2)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 577, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 529, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 645, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 519, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.68.107', port=80): Max retries exceeded with url: /app (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f8a59dd60>: Failed to establish a new connection: [Errno 101] Network unreachable'))
2022-04-30 00:27:33 ERROR (SyncWorker_3) [custom_components.tapo_p100_control.switch] Could not connect to plug. Possibly invalid credentials
2022-04-30 00:27:33 ERROR (MainThread) [homeassistant.components.switch] Error while setting up tapo_p100_control platform for switch
raise err
sock.connect(sa)
self.send(msg)
self.connect()
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPConnection object at 0x7f94f4ed60>: Failed to establish a new connection: [Errno 101] Network unreachable
urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.68.108', port=80): Max retries exceeded with url: /app (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f94f4ed60>: Failed to establish a new connection: [Errno 101] Network unreachable'))
self.update()
requests.exceptions.ConnectionError: HTTPConnectionPool(host='192.168.68.108', port=80): Max retries exceeded with url: /app (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7f94f4ed60>: Failed to establish a new connection: [Errno 101] Network unreachable'))
2022-04-30 00:27:39 ERROR (MainThread) [aionanoleaf.nanoleaf] You are using a test version of aionanoleaf to fix issue 67816
