TL;DR
After Nanoleaf Essentials are added to HASS via the HomeKit Device integration, they lose the ability to create scenes in the Nanoleaf iOS app. It seems the only way to get buttery smooth scene support is through the official Nanoleaf app on Desktop. Couldn’t we leverage an installation of this through Home Assistant to spin up custom made intricate scenes with very little overhead?
The Basics
Nanoleaf Essentials are able to smoothly transition with the same scenes (effects) as Nanoleaf Shapes
These scenes are created in the Nanoleaf App. If given permission, they will create scenes in HomeKit allowing you to retrieve dynamic scenes with the push of a button, or even a request from Siri
The Nanoleaf app is a dream for creating effects. It even has a gimmick that generates scenes based off of keywords you entered (sort of a psuedo-AI thing) which generally makes the experience faster and and more visually accessible than building in YAML.
The Problem
Because Essentials are Thread-only (especially my HomeKit versions), they must be paired directly to HASS and then bridged to HomeKit. This is unlike the Shapes, which can remain paired to HomeKit and be paired to HASS through the Nanoleaf integration
Once the Essentials are on HASS I can no longer transfer scenes to them through the iOS app. I’m not sure the reasoning for this, but whenever I create a scene with the Essentials it gives me an error with a different code each time.
As a result, there’s no way to quickly call on the scenes that I’ve come to love with Nanoleaf.
To top this all off, Nanoleaf Essentials don’t work with the standard transition data used in the light.turn_on service! I’ve already encountered someone who remedied this with a custom script, but it is still far from desirable and and has no color support.
The Question
Could we not leverage whatever tools the Nanoleaf Deskop App is using to create and call on scenes for bulbs that are paired to HASS through the HomeKit Device Integration?
I can manually manage this, but it literally requires me to pull out my laptop each time.’
Oh wow I had not seen this! So we could potentially create an integration to call scenes for Nanoleaf essentials? That would be a true game changer. Have you been able to force a color fade on the bulb from HASS or any other troubleshooting software?
I’d love to help if there’s some sort of grunt work that needs to be done to decode how scenes are handled. I dream of creating a singular scene in Home Assistant that can be pushed to the bulbs, rather than the current infrastructure that requires you create the scene within the nanoleaf app and then “share” it to the other bulbs. Is it actually storing the scene within in the bulb? There’s no way, right? So then WHY does the bulb have it’s own version of the scene that does not get updated if you tweak it on another bulb? It’s an iterative nightmare that would be much more manageable if you could leverage HASS and Node Red to help.
Sorry for the late reply, I had no idea anyone even read this.
I’d love to get at least the effect control feature, which would allow me to activate the scene installed on the device from Home Assistant using the effects settings of the light entity.
I have managed to combine all Nanoleaf devices (old Aurora, new Matter A19 Bulb, Floor Lamp) and Govee into group scenes with effects. To do this, the Nanoleaf Matter devices must have the latest firmware 4.0.0. You need to get a token for each of them for local control. Then integrate into Home Assistant. There I created scenes with the desired effects and transferred them to HomeKit via integration.
Would you mind telling us how you did that? There seems to be quite a lot of people including myself who are looking for a solution to this exact problem. In my case the dynamic nanoleaf scenes stored in the bulb are accessible on neither the matter over thread NL67s or the their NL45 homekit counterparts controlled though the matter server and a homekit integration, respectively, using the SLZB-MR3U as a TBR.
