Hi All,
I see this error many times. The lights go on, but its not ok to see those errors.
Reset my Nanoleaf didn’t help. Restart HA didn’t help.
I can control the nanoleaf in HA, colors, effect, brightness etc…
What can this be?
2021-03-28 20:14:41 ERROR (MainThread) [homeassistant.components.automation.scene_evening_automation] Scene - Evening Automation: Error executing script. Unexpected error for call_service at pos 5: 192.168.100.2 is not available
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 445, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 440, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
response.begin()
File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.8/http/client.py", line 268, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.8/socket.py", line 669, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 531, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 735, in reraise
raise value
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 447, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.100.2', port=16021): Read timed out. (read timeout=2)
File "/usr/local/lib/python3.8/site-packages/pynanoleaf/pynanoleaf.py", line 188, in _request
response = self._session.send(req.prepare(), timeout=self.timeout)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.100.2', port=16021): Read timed out. (read timeout=2)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 262, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 463, in _async_call_service_step
await service_task
File "/usr/src/homeassistant/homeassistant/core.py", line 1488, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1523, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 204, in handle_service
await self.hass.helpers.service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 642, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 681, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 679, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/light/__init__.py", line 235, in async_handle_light_on_service
await light.async_turn_on(**params)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 707, in async_turn_on
await self.hass.async_add_executor_job(ft.partial(self.turn_on, **kwargs))
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/nanoleaf/light.py", line 217, in turn_on
self._light.effect = effect
File "/usr/local/lib/python3.8/site-packages/pynanoleaf/pynanoleaf.py", line 175, in effect
self._put("effects", {"select": value})
File "/usr/local/lib/python3.8/site-packages/pynanoleaf/pynanoleaf.py", line 219, in _put
self._request(path, 'PUT', data)
File "/usr/local/lib/python3.8/site-packages/pynanoleaf/pynanoleaf.py", line 194, in _request
raise Unavailable("{} is not available".format(self.host)) from e
pynanoleaf.pynanoleaf.Unavailable: 192.168.100.2 is not available
2021-03-28 20:14:41 ERROR (MainThread) [homeassistant.components.automation.scene_evening_automation] While executing automation automation.scene_evening_automation
response.begin()
raise value
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 412, in async_trigger
await self.action_script.async_run(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1041, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 254, in async_run
await self._async_step(log_exceptions=False)
await getattr(
await service_task
task.result()
await coro
await result
