Hi, I have a Nanoleaf Shapes and a Nanoleaf Elements in my home. I added them to HA with the integration and the appear to work fine.
But my logs are swamped with this:
2023-01-19 04:12:11.857 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-01-19 04:12:48.218 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-01-19 04:12:54.338 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 1
Logger: homeassistant.components.nanoleaf
Source: components/nanoleaf/__init__.py:88
Integration: Nanoleaf (documentation, issues)
First occurred: 17 January 2023 at 02:50:55 (740 occurrences)
Last logged: 07:07:43
In the above this is coming at 04:12am, no one is awake so for sure not interacting with the lights. These came within seconds, sometimes there might be 20 minutes between them. I notice now occasionally there may be a few hours were it stops, then it begins again for hours flooding the logs with these entries. Always ID 0, 1 and 6 from what I can tell.
I search the forums and google for ‘Received unknown touch gesture ID’ and I come up mostly blank. Does anyone know what this means, presumably as not seeing it from anyone else it’s something my side. Maybe I haven’t set the devices up correctly or the integration?
I have the exact same issue! Since a few weeks these errors appear in my log and i also notice the Nanoleaf turning on at random during the night or when we are away. Did not find the cause yet…
I don’t see an issue opened for this so it’s probably time to do that. I had to re-pair both of my Nanoleaf shapes when they upgraded their firmware a month or two ago. I don’t remember this happening before then. Can anybody here say for sure when this happened? I don’t keep check logs as much as I should.
Just wanted to chime in and say I have the same issue, no solution. I don’t worry too much about the log because they are not too frequent and they are warnings. But I do worry about them coming on by themselves.
I have noticed it cycles mostly between ID 0 and ID 6 for me, not seen many 1 recently. There is no structure to time either. Here is for example a snippet of the last 20 rows of my log:
2023-11-04 08:45:22.686 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 08:47:15.725 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 09:10:30.736 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 09:27:00.016 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 09:32:48.856 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 11:05:01.146 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 11:06:07.026 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 11:23:33.188 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 11:32:01.868 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 11:34:13.988 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 11:43:48.908 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 11:57:28.989 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 12:11:08.709 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 12:17:24.189 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 12:17:26.349 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:17:29.589 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:17:34.989 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:20:05.469 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:20:32.109 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:21:30.429 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:21:37.629 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:21:48.069 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:22:02.829 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:22:11.109 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:23:14.829 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:23:19.509 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 1
2023-11-04 12:23:22.749 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 12:23:29.230 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 0
2023-11-04 12:23:31.389 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 6
2023-11-04 12:23:40.029 WARNING (MainThread) [homeassistant.components.nanoleaf] Received unknown touch gesture ID 1
