Thanks for recognizing the avatar! Sorry for the holiday related delay…
You can’t program the Lines segment by segment from HA (at least, when I set this up, you couldn’t), so you have to create various scenes to match the possible states. I named them things like “Green 16” and “Blue 36” to mean e.g. a green stem with 1/6 petals lit up. So I needed an automation to set the right scene at a given time.
I have a numeric input for the daily target of production that I can change around, but I leave it at roughly the max my system can produce, around 45 kwh.
I created two template sensors shown below. The first compares current production to consumption and is simply a true/false value. The second takes in the day’s solar production and compares it to the target, and outputs a value of 0 thru 6.
template:
- sensor:
- name: "Solar Production"
unique_id: "solar_production_template"
state: '{{ int(states("sensor.envoy_current_power_production")) > int(states("sensor.envoy_current_power_consumption")) }}'
icon: mdi:weather-sunny
- name: "Daily Achievement"
unique_id: "solar_achievement_template"
state: '{% if( int(states("sensor.envoy_today_s_energy_production"))
> int(states("input_number.solar_target")) ) %}6{%
elif( int(states("sensor.envoy_today_s_energy_production")) > int(states("input_number.solar_target"))*5/6) %}5{%
elif( int(states("sensor.envoy_today_s_energy_production")) > int(states("input_number.solar_target"))*4/6) %}4{%
elif( int(states("sensor.envoy_today_s_energy_production")) > int(states("input_number.solar_target"))*3/6) %}3{%
elif( int(states("sensor.envoy_today_s_energy_production")) > int(states("input_number.solar_target"))*2/6) %}2{%
elif( int(states("sensor.envoy_today_s_energy_production")) > int(states("input_number.solar_target"))*1/6) %}1{%
else %}0{% endif %}'
Finally, I have a helper toggle called Solar Status Mode that I use automations to turn on at sunrise and off at sunset. I set other various scenes manually on the Lines at night. With solar status mode on, an automation tracks any change to the two template sensors, and triggers a script.
This is the automation that triggers the update script:
- id: '1637546180412'
alias: Set Nanoleaf Lines to Solar Status
description: ''
- platform: state
entity_id: sensor.daily_achievement
- platform: state
entity_id: sensor.solar_production
condition:
- condition: state
entity_id: input_boolean.solar_status_mode
state: 'on'
- service: script.solar_status_setup
mode: single
And here’s the script that assigns the right scene (Nanoleaf calls it a scene, in HA terms it’s an effect) to the Lines. It has a template that assembles the two sensor values from earlier into an effect name:
solar_status_setup:
alias: Solar Status Update
sequence:
- service: light.turn_on
entity_id: light.lines_bcbc
effect: '{% if(is_state("sensor.solar_production", "True")) %}Green {% else
%}Blue {% endif %}{{ states("sensor.daily_achievement") }}6'
mode: single
Enjoy setting up the Lines, they are really cool looking. I have some Nanoleaf Shapes as well, which I like, but IMO the Lines are vastly superior. Let me know if you have questions about this code and post pictures if you get it working!
