Nanoleaf Single tap and Dual tap touch events
Hi All,
I’m new to Home Assistant and I’m seeking advice on the below topic.
I’m using the Nanoleaf integration with my Elements, and I get the swipe_up, down, left, right events as expected. I’ve seen that the Nanoleaf integration gets the events using the aionanoleaf package.
In the source of that it is visible that it could recognize single tap and dual tap events as well:
aionanoleaf/aionanoleaf /events.py
I’m wondering, if I could enable this on my Home Assistant Green by making a custom version of the Nanoleaf integration by copying it to custom_components and modifying the below file to include them in TOUCH_GESTURE_TRIGGER_MAP? Or is that not enough, would anything else be needed? Did anyone try to catch these events?
homeassistant/components/nanoleaf/const.py
I would modify it to this:
TOUCH_GESTURE_TRIGGER_MAP = {
    0: "single_tap",
    1: "double_tap",
    2: "swipe_up",
    3: "swipe_down",
    4: "swipe_left",
    5: "swipe_right",
I haven’t checked, but has someone done a blueprint for these. Easier to work with automations than customize your own integration. Lots of things to worry about playing in that zone.
I’ve found this thread regarding a relevant blueprint, and I am using it already. If I understand correctly, this takes events from the Nanoleaf integration, so it can only use what is made available there.
Nanoleaf - Gestures
I’m yet to find other blueprints for this topic.
