Trying to connect my HA OS 2023.6.2 to my synology nas and it just doesn’t work
Can anyone see anything wrong here?
Error in log is also pretty useless:
2023-06-15 17:41:17.275 ERROR (MainThread) [homeassistant.components.hassio] Failed to to call /mounts - Mounting nas did not succeed. Check host logs for errors from mount or systemd unit mnt-data-supervisor-mounts-nas.mount for details.
ludeeus
(Ludeeus)
June 15, 2023, 4:44pm
2
The error is pretty useless because that’s not the error, it tells you where to look for the error…
And you share is wrong use / not \
Also, make sure you have smb 2.1+ active on the server.
Tried just backup and still the same so it’s not that.
Not sure it can set 2.1 anywhere
Changed max version to SMB3 and that did the trick thanks
Also change min version to 2.0. Version 1.0 is not exactly safe to have it enabled…
That’s exactly what I had done
acamaz-ch
(Acamaz Ch)
November 13, 2024, 5:05pm
7
Thank you! It worked for me too!
