I am using a Fritzbox with a connected USB drive to save my backups (my Synology NAS contains the VM for HA - so not a good idea to store the backup there).
Now configuring it works fine, also the test backup, but every morning I get an error in supervisor. Backing up manually also wont work. Only when I got to System → Storage and re-insert the login credentials it works again. Clueless here
OSError: [Errno 112] Host is down: ‘/data/mounts/Fritzbox/72db9248.tar’
24-02-21 07:47:19 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py”, line 452, in _handle_request
resp = await request_handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py”, line 543, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py”, line 114, in impl
return await handler(request)
File “/usr/src/supervisor/supervisor/api/middleware/security.py”, line 186, in block_bad_requests
File “/usr/src/supervisor/supervisor/api/middleware/security.py”, line 202, in system_validation
File “/usr/src/supervisor/supervisor/api/middleware/security.py”, line 269, in token_validation
File “/usr/src/supervisor/supervisor/api/middleware/security.py”, line 280, in core_proxy
File “/usr/src/supervisor/supervisor/api/utils.py”, line 63, in wrap_api
answer = await method(api, *args, **kwargs)
File “/usr/src/supervisor/supervisor/api/backups.py”, line 139, in list
data_backups = self._list_backups()
File “/usr/src/supervisor/supervisor/api/backups.py”, line 123, in _list_backups
ATTR_SIZE: backup.size,
File “/usr/src/supervisor/supervisor/backups/backup.py”, line 187, in size
if not self.tarfile.is_file():
File “/usr/local/lib/python3.12/pathlib.py”, line 892, in is_file
return S_ISREG(self.stat().st_mode)
File “/usr/local/lib/python3.12/pathlib.py”, line 840, in stat
return os.stat(self, follow_symlinks=follow_symlinks)
24-02-21 07:47:29 ERROR (MainThread) [supervisor.backups.manager] Could not list backups from /data/mounts/Fritzbox: [Errno 112] Host is down: ‘/data/mounts/Fritzbox’
24-02-21 07:47:29 INFO (MainThread) [supervisor.backups.manager] Found 1 backup files
24-02-21 07:47:40 ERROR (MainThread) [supervisor.backups.manager] Could not list backups from /data/mounts/Fritzbox: [Errno 112] Host is down: ‘/data/mounts/Fritzbox’
