kwladyka
(Krzysztof Władyka)
January 21, 2021, 9:50pm
1
Hey, I found only basic configuration to achieve this, but there is much more work to do. I want to make from this topic full configuration for NAS Synology and zigbee.
What I have learned so far:
Docker installation work, but has no “Supervisor” so it is not useful, because I can’t install add-ons, which are necessary to run zigbee. The only one way then is to use docker-compose
My current configration:
version: '3'
services:
homeassistant:
image: homeassistant/home-assistant:stable
environment:
- TZ=Europe/Warsaw
volumes:
- ../home-assistant/config:/config
devices:
- /dev/bus/usb/003/003:/zwaveusbstick
restart: unless-stopped
network_mode: host
eclipse-mosquitto:
image: eclipse-mosquitto:latest
volumes:
- ../mqtt/config:/mosquitto/config/
- ../mqtt/data:/mosquitto/data
- ../mqtt/log:/mosquitto/log
network_mode: host
nodered:
image: nodered/node-red
volumes:
- ../node-red:/data
network_mode: host
What I have to figure out:
I have very strange path to USB adapter /dev/bus/usb/003/003
hmm. There is no /dev/serials
folder. /dev/tty*
don’t look helpful too.
MQQT and node-red don’t start, because of luck of configuration files. Can you share this things with me?
Do I need more docker images to make it work? More configurations?
Is there any FULL ready docker-compose with configurations to run home-assistant with zigbee? It should be! Can someone share everything?
kwladyka
(Krzysztof Władyka)
January 24, 2021, 5:54pm
2
My configuration which work. It should save you 95% of time to set this up.
First of all you have to install drivers for your stick. In my case http://www.jadahl.com/drivers_6.2/ for slaesh’s CC2652RB stick. Without this NAS Synology will not make /dev/ttyUSB0
version: '3'
services:
homeassistant:
environment:
- TZ=Europe/Warsaw
volumes:
- ./home-assistant/config:/config
network_mode: host
eclipse-mosquitto:
# volumes:
# - ./mosquitto/config/mosquitto.conf:/mosquitto/config/mosquitto.conf
network_mode: host
zigbee2mqtt:
image: koenkk/zigbee2mqtt
volumes:
- ./zigbee2mqtt/data:/app/data
- /run/udev:/run/udev:ro
devices:
- /dev/ttyUSB0:/dev/ttyACM0
network_mode: host
environment:
- TZ=Europe/Warsaw
nodered:
# volumes:
# - ./node-red:/data
network_mode: host
home-assistant/config/configuration.yaml
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# https://github.com/vigonotion/hass-simpleicons
simpleicons: true
panel_iframe:
nodered:
title: 'Node-red'
url: 'http://your-host:1880'
icon: si:node-red
mqtt:
broker: localhost
# username:
# password:
discovery: true
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
zigbee2mqtt/data/configuration.yaml
# https://www.zigbee2mqtt.io/information/configuration.html
homeassistant: true
permit_join: true
mqtt:
base_topic: zigbee2mqtt
server: 'mqtt://localhost'
serial:
port: /dev/ttyACM0
devices: devices.yaml
groups: groups.yaml
advanced:
log_output:
- console
network_key: '!secret network_key'
todo:
network_mode: host
It is possible to turn this off, but it requires to set up mDNS and UPnP extra for homeassistant service. I don’t want to spend my time on this at that moment.
