I know this is a late response but when I hear someone mention they’re not using a UPS on their computers, I cringe!
Running any computer, especially a Windows PC, without a battery backups is like playing Russian Roulette with your hardware and data. Think of an old record player spinning (I’m showing my age here) and you suddenly remove the power and drag the needle across the record. What do you get, a scratched record. Now imaging a hard drive running at 7200 RPM’s, writing data to it, and you pull the plug. There’s goes your data! Let’s not forget about the corruption it leaves behind.
In addition, unlike Linux, Windows doesn’t always do a disk repair upon reboot after a crash. The disks are left in a corrupted state.
Now that’s just the data. Let’s talk about the damage caused to the equipment. Power into your home and/or business is no where near clean. There can be numerous dips and/or brownouts through out the day, so subtle that you can’t even see them. However, they are enough to damage your equipment. Motherboard, drives, memory, power supply, monitor, you name it.
Take it from someone who has learned from experience. Early in my career I moved to Florida (over 25 years ago), I’ve since relocated, and spent 6 month reloading my PC over and over again due to corruption, lockups, you name it. Until a friend ask me “do you have a UPS”? One UPS later and my issues disappeared immediately. Florida is know for poor electrical, more so then where I’m originally from so it never dawned on me. Up until then I was just lucky.
Every PC, except a laptop since it already has one, should have a UPS. As I mentioned above, they don’t just maintain power if it goes out, it also protects against surge, drops, and brownouts.
I recommend APC, they’ve never failed me. Cyberpower on the other hand has on several occasions.
