Following up from my other post (Use Nabu Casa URL to use HA API?) I was wondering if it was possible to have this type of config on the ESP to connect remotely to the Home Assistant API?
Example:
# Example configuration entry
api:
password: 'MyPassword'
NabuCasa: https://YOUR_NABU_CASA_URL_HERE.ui.nabu.casa #else from secrets.yaml
LongLivedToken: ******************* #else from secrets.yaml
So I suppose I would need to engineer another way to easily add this to each sensor on my ESPs.
Could you recommend any other features to do so?
Thinking something along the lines of having majority of the HTTP command script in another file using Includes - Then each node can be edited to include that file.
For the sensors, would that need some experienced templating?
So I could include the core of the HTTP Request, then template each sensor on each node…?
Sorry for the lack of knowledge - just using the example from my previous post…
button:
# Button on press calls the http command
on_press:
then:
- http_request.post:
method: POST
## Change IP and Sensor name within the substitutions
## You can use the local or remote IP
## Remember the URL has /api/states/ hard coded
url: $NabuCasaAddress/api/states/$BearerSensorName
headers:
Authorization: !secret bearer_token
Content-Type: application/json
verify_ssl: false
json:
## You can customize this part but remember to include 'state'
root["state"] = id(uptime_human).state;
## Add more data / attributes here
## Refer to Home Assistant API Docs
## https://developers.home-assistant.io/docs/api/rest/
