So I figured out the ShellyForHass HACS components wasn’t maintained for quite some time, which made me switch to the native one.
Everything seems fine as long as I add every single Shelly device on it’s own by it’s IP address. But I read they should be auto dicovered? How does that work, what do I have to do to make it work? It is mentioned most of the times together with MQTT.
Do I have to set up MQTT in addition o CoIoT in the Shelly config?
MQTT is disabled, CoIoT is enabled and configured to use unicast. Could it be a problem that the Shellys are on a different network as HASS? Nevertheless I drilled the needed holes into the router, which is proved once I added the IP manually and everything runs smoothly.
Waking up should be pushing a connected switch or opening the web interface? Tried both.
Firmware is 20230913-112003/v1.14.0-gcb84623 and discoverability is enabled in the Shelly’s web UI
Any more ideas? How is the discovery setup tech-wise? Does HASS just listening on port 5683 for messages of new devices?
