Has anyone updated to .91.1 and has it resolved the issue?
This is the fix. One can use the custom component in the meantime.
Dear, someone here guide me.
I would like to turn on my androidtv box with broadlink.
How to add custom command in turn on command provided in new config.
dear,
i would like to add broadlink send packet for turning on androidtv as turn_on_command.
Please guide, how to do?
thanks in adv
Hi there,
I am trying to set up my nvidia shield tv as android tv using ADB but it is not working.
Out of the box HA discover Nvidia as casting device, but when I try to set up androidtv component I am getting error:
Exception occurred:
File "/usr/local/lib/python3.7/site-packages/zeroconf.py", line 2101, in send
bytes_sent = s.sendto(packet, 0, (addr, port))
PermissionError: [Errno 1] Operation not permitted
Any help please.
Did you use the ADB server method using the ADB add-on for Hassio?
If not, how have you tried to set things up?
Ok so from start I did not install anything and HA out of the box recognized in Integrations:
Google cast with
NVIDIA TV
media_player.nvidia_tv
I can control a bit this one turn on but not off, volume sometimes works, skipping tracks works.
In entities I have additional player as well
Kodi on Shield
media_player.kodi_android_3_local
kodi
And there is an error in the HA
Exception occurred: Traceback (most recent call last): File "/usr/local/lib/python3.7/site-packages/zeroconf.py", line 2101, in send bytes_sent = s.sendto(packet, 0, (addr, port)) PermissionError: [Errno 1] Operation not permitted
But after installing ADB bridge I finally can connect to nvidia on port 5555 and player appeared on Overview NVIDIA TV
com.google.android.tvlauncher
I can control it on/off, etc. So all good it seems but that error about zeroconf.py is still in the logs so should I disregard it?
How to turn off google cast integration which start at? do not want this one.
Cheers
Hey all of you,
i had my firth working befor 91.4 but now it doesnât work anymore. does anyone has a clue how to fix it? my config: error i get is
Could not connect to Fire TV at 192.168.178.53:5555 using ADB server at 127.0.0.1:5037
- platform: androidtv
device_class: firetv
host: xxx.xxx.xxx.xxx
adbkey: "/home/pi/.android/adbkey"
get_sources: true
adb_server_ip: 127.0.0.1
Try reconnecting, restarting, reconnectin
hey thanks for the quick answer first of all, do you mean:
add kill-server
adb start-server
adb connect xx.xx.xxx
sudo systemctl restart home-assistant
I had to restart my android device (fire tv), then restart home assistant after the device booted back up.
that finally worked for me, got my component back running!
thanks to all of you!
media_player.volume_up and media_player.volume_down services stopped working for NVIDIA Shield with HA 0.92
Everything is working for me. 0.92.1 installed. Thanks.
Iâm trying to start an android app using the example on the component page:
sequence:
- service: media_player.select_source
entity_id: media_player.fire_tv_living_room
source: 'com.netflix.ninja'
With my own configuration offcourse:
sequence:
entity_id: media_player.android_tv
source: 'nl.nlziet'
But there is no result. Nothing. What am I missing?
Iâm using this addon with a FireTv Stick and its working great! However the state doesnât reflect wether its currentl playing or not. As soon as I launch an App (Netflix/Amazon Video) it stays as âpausedâ independently wether im playing or paused.
Is this a known issue?
Itâs a known issue and isnât easily solvable.
For Fire TV devices, you can launch an app using the
command.
This is only supported for Fire TV devices.
But you can launch apps using intents from here: ADB intents.
Thanks. Iâll try that
Hello.
I created the folder config\custom_components\androidtv and have in it the files:
init.py
media_player.py
manifest.json
and a folder pycache
In this folder there are 2 files: init.cpython-37.pyc & media_player.cpython-37.pyc
In my config file I have:
host: xxx.xxx.xx.xxx
apps:
netflix: âNetflixâ
adb_server_port: 5037
I am also running the add-on ADB - Android Debug Bridge V 0.4.1
In HA.log file I get:
WARNING (SyncWorker_6) [custom_components.androidtv.media_player] Could not connect to MIBOX3 at xxx.xxx.xx.xxx:5555
Also enabled USB Debugging in mibox3 and checked the pop up allowing access.
What am I doing wrong??? I am confused a bitâŚ
Thanks!
