EDITED: 5/30/2024 - Updated the configuration file
I have a Navien Hot Water Heater, that uses RS-485 to communicate. What I am trying to build is an ESP32 Interface for this unit, and have quite a bit of it working. I am hoping to find that help here and allow me to finish out the last few items that will make this complete!. In a thread here, contains most of the details.
Below is my current Configuration and a snip from the subsequent web page it produces.
I am confident there are better/more efficient ways to produce this, but with my basic knowledge of cutting and pasting code together, I have managed to stumble my way along to get here. I am open to any and all help you and provide!
Thanks!
#### REVISION HISTORY ####
# 5/28/2024 revision to gas m3, ccf, and therms per discussion on community forum
#### TO DO ####
# Modify setpoint to be an input text or value
# remove fake switch
substitutions:
comment: "(Navien Hot Water Heater) -- Device host: redacted"
friendly_name: Navien Water Heater
logger_level: WARN
# Include basic info in all ESP Home Configs
# Basic Info Includes
# logger:
# wifi:
# ap:
# web_server:
# captive_portal:
# button: to restart the device
<<: !include .base1.yaml
binary_sensor:
- platform: status
internal: True
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: ${logger_level}
baud_rate: 0 #disable logging over uart
# Enable Home Assistant API
api:
encryption:
key: "redacted"
ota:
password: "redacted"
globals:
- id: init_set_temp
type: int
restore_value: yes
initial_value: '140'
#### UART SETUP/DECODE BYTES ####
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 19200
data_bits: 8
stop_bits: 1
parity: NONE
debug:
direction: BOTH
dummy_receiver: True
after:
delimiter: "\n"
sequence:
- lambda: |-
// SPECIAL THANKS TO @suva on the HomeAssistant forum for Decoding these.
// https://community.home-assistant.io/t/navien-hot-water-heater-navilink/330044/92
UARTDebug::log_string(direction, bytes);
if (bytes[0] == 247 && bytes[1] == 5 && bytes[2] == 80 && bytes[3] == 80 && bytes[4] == 144 && bytes[5] == 34) {
// Water information
id(uart_water_byte0).publish_state(bytes[0]); //Common To all Packets
id(uart_water_byte1).publish_state(bytes[1]); //Common To all Packets
id(uart_water_byte2).publish_state(bytes[2]); //Packet id Byte 0
id(uart_water_byte3).publish_state(bytes[3]); //Packet id Byte 1
id(uart_water_byte4).publish_state(bytes[4]); //Packet id Byte 2
id(uart_water_byte5).publish_state(bytes[5]); //Data Length
id(uart_water_byte6).publish_state(bytes[6]);
id(uart_water_byte7).publish_state(bytes[7]);
id(uart_water_byte8).publish_state(bytes[8]);
id(uart_water_byte9).publish_state(bytes[9]); // System Power: high nibble: Unknown (values 0 and 0x20 observed); low nibble = 0=off 0x5=on
id(uart_water_byte10).publish_state(bytes[10]);
id(set_temp_read).publish_state((bytes[11]/2)); //Set temp - measured in 0.5 degrees C.
id(outlet_temp).publish_state((bytes[12]/2)); //Outlet temp - measured in 0.5 degrees C.
id(inlet_temp).publish_state((bytes[13]/2)); //Inlet temp - measured in 0.5 degrees C.
id(uart_water_byte14).publish_state(bytes[14]);
id(uart_water_byte15).publish_state(bytes[15]);
id(uart_water_byte16).publish_state(bytes[16]);
id(uart_water_byte17).publish_state(bytes[17]);
id(water_flow_lpm).publish_state(bytes[18] / 10); //Flow rate - measured in 0.1 liters per minute (divide by 10 to get LPM)
id(uart_water_byte19).publish_state(bytes[19]);
id(uart_water_byte20).publish_state(bytes[20]);
id(uart_water_byte21).publish_state(bytes[21]);
id(uart_water_byte22).publish_state(bytes[22]);
id(uart_water_byte23).publish_state(bytes[23]);
id(uart_water_byte24).publish_state(bytes[24]); //System status. Probably a bitwise field. Partially decoded: display units: 0x08 position: 1=metric 0=imperial. 0x02 position: 1=weekly 0=hotbutton
id(uart_water_byte25).publish_state(bytes[25]);
id(uart_water_byte26).publish_state(bytes[26]);
id(uart_water_byte27).publish_state(bytes[27]);
id(uart_water_byte28).publish_state(bytes[28]);
id(uart_water_byte29).publish_state(bytes[29]);
id(uart_water_byte30).publish_state(bytes[30]);
id(uart_water_byte31).publish_state(bytes[31]);
id(uart_water_byte32).publish_state(bytes[32]);
id(uart_water_byte33).publish_state(bytes[33]);
id(uart_water_byte34).publish_state(bytes[34]);
id(uart_water_byte35).publish_state(bytes[35]);
id(uart_water_byte36).publish_state(bytes[36]);
id(uart_water_byte37).publish_state(bytes[37]);
id(uart_water_byte38).publish_state(bytes[38]);
id(uart_water_byte39).publish_state(bytes[39]);
id(uart_water_byte40).publish_state(bytes[40]);
else if (bytes[0] == 247 && bytes[1] == 5 && bytes[2] == 80 && bytes[3] == 15 && bytes[4] == 144 && bytes[5] == 42) {
// Gas information
id(uart_gas_byte0).publish_state(bytes[0]); //Common to All Packets
id(uart_gas_byte1).publish_state(bytes[1]); //Common to All Packets
id(uart_gas_byte2).publish_state(bytes[2]); //Packet id Byte 0
id(uart_gas_byte3).publish_state(bytes[3]); //Packet id Byte 1
id(uart_gas_byte4).publish_state(bytes[4]); //Packet id Byte 2
id(uart_gas_byte5).publish_state(bytes[5]); //Data Length
id(uart_gas_byte6).publish_state(bytes[6]);
id(uart_gas_byte7).publish_state(bytes[7]);
id(uart_gas_byte8).publish_state(bytes[8]);
id(uart_gas_byte9).publish_state(bytes[9]);
id(uart_gas_byte10).publish_state(bytes[10]);
id(uart_gas_byte11).publish_state(bytes[11]);
id(uart_gas_byte12).publish_state(bytes[12]);
id(uart_gas_byte13).publish_state(bytes[13]);
id(uart_gas_byte14).publish_state(bytes[14]);
id(uart_gas_byte15).publish_state(bytes[15]);
id(uart_gas_byte16).publish_state(bytes[16]);
id(uart_gas_byte17).publish_state(bytes[17]);
id(uart_gas_byte18).publish_state(bytes[18]);
id(uart_gas_byte19).publish_state(bytes[19]);
id(uart_gas_byte20).publish_state(bytes[20]);
id(uart_gas_byte21).publish_state(bytes[21]);
id(low_byte_kcal).publish_state(bytes[22]); //Low byte current gas usage in kcal
id(high_byte_kcal).publish_state(bytes[23]); //High byte current gas usage in kcal
id(total_gas_use_m3).publish_state(bytes[24] / 10); //Total gas usage in 0.1m^3 (divide by 10 to get m^3)
id(uart_gas_byte25).publish_state(bytes[25]);
id(uart_gas_byte26).publish_state(bytes[26]);
id(uart_gas_byte27).publish_state(bytes[27]);
id(uart_gas_byte28).publish_state(bytes[28]);
id(uart_gas_byte29).publish_state(bytes[29]);
id(uart_gas_byte30).publish_state(bytes[30]);
id(uart_gas_byte31).publish_state(bytes[31]);
id(uart_gas_byte32).publish_state(bytes[32]);
id(uart_gas_byte33).publish_state(bytes[33]);
id(uart_gas_byte34).publish_state(bytes[34]);
id(uart_gas_byte35).publish_state(bytes[35]);
id(uart_gas_byte36).publish_state(bytes[36]);
id(uart_gas_byte37).publish_state(bytes[37]);
id(uart_gas_byte38).publish_state(bytes[38]);
id(uart_gas_byte39).publish_state(bytes[39]);
id(uart_gas_byte40).publish_state(bytes[40]);
} else {
// Handle other cases
#### ENABLE/DISABLE HEATER ####
switch:
name: "HW Heater On/Off"
restore_mode: ALWAYS_ON
icon: mdi:water-boiler
lambda: |-
if ((id(uart_water_byte9).state) == 5) {
return true;
id(navien_switch).publish_state(true);
} else {
return false;
id(navien_switch).publish_state(false);
turn_on_action:
- uart.write: !lambda
return {0xf7, 0x05, 0x0f, 0x50, 0x10, 0x0c, 0x4f, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xce};
turn_off_action:
return {0xf7, 0x05, 0x0f, 0x50, 0x10, 0x0c, 0x4f, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa};
name: "Fake Thermostat Switch"
optimistic: True
internal: True
#### SETPOINT ENTRY TEMPLATE - STILL WORKING ON THIS 4/29/2024 ####
climate:
- platform: thermostat
name: "Climate Controller"
visual:
min_temperature: 120 °F
max_temperature: 140 °F
temperature_step: 1.0 °F
sensor: outlet_temp
min_heating_off_time: 300s
min_heating_run_time: 300s
min_idle_time: 30s
heat_action:
- switch.turn_on: fake_switch
idle_action:
- switch.turn_off: fake_switch
#### WATER TEMPLATE SENSORS ####
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: true
internal: True
name: "Temp Set - Read"
icon: mdi:thermometer-water
unit_of_measurement: °C
accuracy_decimals: 1
device_class: "temperature"
state_class: "measurement"
internal: True
internal: True
internal: True
internal: True
name: "Water Flow LPM"
id: water_flow_lpm # multiply by 0.2642 to get GPM
icon: mdi:water-percent
unit_of_measurement: l/min
name: "Water Flow GPM"
id: water_flow_gpm # this is derived from the Water Flow LPM entity
unit_of_measurement: GPM
lambda: |-
return (id(water_flow_lpm).state * 0.2642);
name: "WByte_19 Unknown Flow"
# internal: True
internal: True
internal: True
internal: True
internal: True
name: "WByte_24 Sys Status"
# internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
#### GAS TEMPLATE SENSORS ####
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: true
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
internal: True
name: "Total Gas Use Cubic Meters"
id: total_gas_use_m3 # divide by 2.832 to get CCF
icon: mdi:gas-cylinder
unit_of_measurement: mÂł
internal: False
name: "Total Gas Use CCF"
id: total_gas_use_ccf # this is derived from the entity Total Gas Use Cubic Meters and converts to CCF for comparison to US energy bills.
unit_of_measurement: CCF
internal: False
lambda: |-
return (id(total_gas_use_m3).state/2.832);
name: "Total Gas Use Therms"
id: total_gas_use_therms # this is derived from the entity Total Gas Use CCF and one of the typical measurements for the utility company to bill against in the US.
icon: mdi:gas-cylinder # this multiplier 1.02845 was obtained from my energy bill - it is known as "Therm Factor" on my bill
unit_of_measurement: therms
internal: False
lambda: |-
return (id(total_gas_use_ccf).state * 1.02845);
name: "kCal Low Byte"
icon: mdi:gas-burner
unit_of_measurement: kCal
name: "kCal High Byte"
unit_of_measurement: "kbtu/hr"
accuracy_decimals: 3
lambda: |-
return max((id(outlet_temp).state - id(inlet_temp).state) * id(water_flow_gpm).state * 8.334 * 60 / 0.92 / 1000, 0.0);
# calculated as shown here https://www.plctalk.net/threads/low-byte-high-byte.78315/
accuracy_decimals: 2
lambda: |-
return (id(high_byte_kcal).state*256) + (id(low_byte_kcal).state);
I’m struggling with a few things that I could use some tips on.
- When using the switch I created in ESPHome to turn on/off the Heater, ideally I’d like the switch to set it’s position based on the current status of the unit, then if the switch changes - send the appropriate command. Last, I’d like to know that the command was received and that it has gone into that mode.
- Similar question regarding the setpoint. In my config, I created a second “write” setpoint to try and begin configuring this function - but I’m not sure where to go from here.
In both of those cases, I’d like to have a single value/entity show on the ESPHome web page or entity in HA.
Any and all feedback is appreciated if you see something else here that would make this project better!
