If they were similar in price, is it better to get Navi Link or Navi Link Lite?
depends how many Navien water heaters you have. If you have one, then get the Navi-Link Lite.
Thanks, I ordered the Lite version. I’m so looking forward to make water heating smarter Getting stats is the first step.
Ultimately I want to make the hot button recirc intelligent , like described here:
I built an RS485 sniffer similar to this one: RS485 sniffer
I used the UART settings @tsquared provided (19200, 8N1) (thanks!), and connected the sniffer to a tap on the cat5 cable provided with a Navilink lite. Using this cable, the blue and blue-white wires appear to be the RS485 signals. I connected blue to RS485-B and blue-white to RS485-A.
With no navilink attached, the water heater continuously emits two alternating packets (with a short interval between each). I believe each of them contains continuous status information. Let’s call them A and B. With a navilink connected, the navilink sends an announcement packet (let’s call it C) after each packet from the heater. The result is a stream that looks like: A C B C A C B C…
There is a fourth type of packet when the navilink sends a command. It appears the navilink simply repeats the command several times (typically 6), with no acknowledgement from the heater.
I observed the packets while performing various operations, and I believe I have decoded most of the data and commands available in the navilink app. Here are the packet captures and what I have identified so far.
Common Fields
The first 6 bytes appear to be a packet header. The first two bytes are common to all packets. The next three uniquely identify each of our three packet types. Byte index 5 is the length of the data, not including the header (6 bytes) or the final byte, which I believe is a checksum. In other words, byte index 5 is the length of the packet minus 7 bytes.
Index | Value | Notes |
0 | f7 |
Common to all packets |
1 | 05 |
2 | Packet id byte 0 | |
3 | Packet id byte 1 | |
4 | Packet id byte 2 | |
5 | Data length | |
… | Data | |
N | Checksum |
Packet A (from heater)
This packet seems to have information related to water.
Here is a full example packet:
f7 05 50 50 90 22 42 00 00 05 14 72 37 2e 00 00 00 00 00 00 f8 8e 00 00 02 00 00 00 05 00 07 00 00 02 00 00 00 00 00 00 67
And the fields decoded so far:
0 | f7 |
1 | 05 |
2 | 50 |
Packet id byte 0 |
3 | 50 |
Packet id byte 1 |
4 | 90 |
Packet id byte 2 |
5 | 22 |
Data length |
09 | 05 |
System power: high nibble: unknown (values 0 and 0x20 observed); low nibble: 0=off 0x5=on |
11 | 72 |
Set temp - measured in 0.5 degrees C. 57C in this case |
12 | 37 |
Outlet temp - measured in 0.5 degrees C. 27.5C in this case |
13 | 2e |
Unconfirmed, but possibly inlet temperature? This seems very close to the inlet temperature, but was usually off by 0.5-1.5C. My inlet temperature did not vary enough to analyze more |
18 | 00 |
Unknown, but appeared proportional to water flow rate |
19 | 00 |
Flow rate - measured in 0.1 liters per minute (divide by 10 to get LPM) |
24 | 02 |
System status. Probably a bitwise field. Partially decoded: display units: 0x08 position: 1=metric 0=imperial. 0x02 position: 1=weekly 0=hotbutton |
Packet B (from heater)
This packet seems to have information related to gas.
f7 05 50 0f 90 2a 45 00 0b 01 0c 03 17 00 72 6d 23 00 00 00 00 00 00 00 61 00 00 00 0b 00 1d 00 f6 34 00 00 05 00 00 00 00 00 aa 48 00 00 01 00 b3
0 | f7 |
1 | 05 |
2 | 50 |
Packet id byte 0 |
3 | 0f |
Packet id byte 1 |
4 | 90 |
Packet id byte 2 |
5 | 2a |
Data length |
22 | 00 |
Low byte current gas usage in kcal |
23 | 00 |
High byte current gas usage in kcal |
24 | 61 |
Total gas usage in 0.1m^3 (divide by 10 to get m^3; 9.7 cubic meters in this case) |
Packet C (from navilink)
This appears to be an announcement packet. It tells the heater there is a navilink attached. The heater uses this to disable local setting of the weekly schedule and instead require setting the schedule from the app.
f7 05 0f 50 10 03 4a 00 01 55
Packet D (from navilink)
This is the command packet. I tested each of the following commands: power off, power on, set temp, hotbutton. Each type of command uses a different field. I only ever saw a single field used since I tested it using the navilink app, but the format suggests that more than one command could be combined into a single packet. The navilink repeats the on/off/set commands 6 times. For hotbutton presses, it sends the on command twice followed by the off command once.
Here is a full example:
f7 05 0f 50 10 0c 4f 00 0b 00 00 00 00 00 00 00 00 00 0a
0 | f7 |
1 | 05 |
2 | 0f |
Packet id byte 0 |
3 | 50 |
Packet id byte 1 |
4 | 10 |
Packet id byte 2 |
5 | 0c |
Data length |
8 | 0b |
Power: 0x0a=on 0x0b=off |
9 | 00 |
Set temperature (units of 0.5C: 0x74 is 58C) |
11 | 00 |
Hotbutton: 0x01=press 0x00=release |
Here are all the commands I have seen as full packets (so you can see the checksums):
f7 05 0f 50 10 0c 4f 00 0b 00 00 00 00 00 00 00 00 00 0a : off
f7 05 0f 50 10 0c 4f 00 0a 00 00 00 00 00 00 00 00 00 ce : on
f7 05 0f 50 10 0c 4f 00 00 74 00 00 00 00 00 00 00 00 ea : set to 58
f7 05 0f 50 10 0c 4f 00 00 72 00 00 00 00 00 00 00 00 c4 : set to 57
f7 05 0f 50 10 0c 4f 00 00 00 00 01 00 00 00 00 00 00 6a : hotbutton press
f7 05 0f 50 10 0c 4f 00 00 00 00 00 00 00 00 00 00 00 2a : hotbutton release
Checksum
I believe the final byte is a checksum, but I have not identified the algorithm yet. It would be useful to do so for the commands (especially the temperature set commands).
the easiest option for me was having the bathroom light switch trigger the hot button.
So far this project has been very interesting. I am learning at every turn! This is great information! Thank You @suva! I took what you had, and tried with my limited python skills to pull it into python directly using a RS485/USB adapter. Also, built an ESPHome UART Sniffer as you describe above. In both cases - essentially, It reads the information you show above!! I am now trying to figure out how to manipulate the data to get the respective bits/bytes/strings out of this information.
This brings me to my next question - although you note, and I can see the f7 05 common data for all, the data streamed from the COM port starts long before I can see those values.
For example: The raw stream looks like this - (I **'d the f7 05 for clarity - it shows up 2x in this example.)
b'\xd8\xbc\x1a\x00\xb0\x02\x00\x00\x00\x00\xa6I\x00\x00\x00\x00\xb9\**xf7\x05PP**\x90"B\x00\x00\x05\x14x0*\x00\x00\x00\x00\x00\x00\x00\xaf\x00\x18\x00\x00\x00\x00\xb0\x02\x00\x00\x00\x02\x00\x00\x00\x00\x00\x00\xbb**\xf7\x05P**\x0f\x90*E\x00\x01\x01\x14\x07"\x00x0\x1b\x00\x00\x00\x00\x01\x00\x00\x9f\x1f\x00\x00\xd1\x03Z\n'
Interesting enough - that data stream also shows some weird values like the P or PP next to the 05 among other oddities. I have been able to convert it directly to a hex stream and received the following results which appear more accurate:
0xd8bc1a00b00200000000a64900000000b9f70550509022420000051478302a00000000000000af001800000000b00200000002000000000000bbf705500f902a450001011407220078301b000000000100009f1f0000d1035a0a
It seems like I should be able to slice the hex data stream better than the raw one as it appears more accurate? I am grateful for all the help!
Anyone on Next thoughts on python libraries, or ESPHome coding that helps break this down into a useable format?
I did find this post, but it doesn’t seem “solved”. It links to this post, which talks about custom devices in ESPHome, which currently appears past my abilities. I guess I’m back to the reading and learning phase!
Ok - I worked my way through some really crude python and I have it displaying some information regarding the water, and printing to the REPL. Now that I can actually read it for what data it is supposed to be showing, It appears that I may have some differences from what @suva shows.
As it relates to index 18 & 19 (flow) on the water side. It seems that my water flow is actually index 18, as index 19 never changes for me. Index 19 is always zero. I confirmed that the front panel shows the value I am calculating on index 18 in the code, back to GPM.
Also, index 13 - that value seems strange to be inlet temperature. Guess I will have to keep watching and comparing that value to the front panel of the unit and see what it says.
I got my module today. Navilink Lite is using STM32F412 for MCU and MXCHIP EMC3280-E for WIFI.
Making some progress here! Again - thanks to @suva for all his decoding! I started with some generic python code to make sure I could actually talk/receive information from the device. The code I wrote to receive the information from my equipment is below. I am certain that it’s not efficient, and likely doesn’t follow too many rules for coding. If anyone has any tips here they are appreciated!
import time
import serial
print ("Opening port")
try:
ser = serial.Serial('COM3',19200,bytesize=8,
parity=serial.PARITY_NONE,
stopbits=serial.STOPBITS_ONE,
timeout=0)
print ("Port is open")
except serial.SerialException:
serial.Serial('COM3', 19200).close()
print ("Port is closed")
serial_port = serial.Serial("COM3",19200)
print ("Port is open again")
print ("Ready to use")
buffer = bytearray(b'')
buffer_length = 99
buf_list = []
while True:
try:
buffer += ser.read()
if len(buffer) <= buffer_length:
buffer += buffer
elif len(buffer) >= buffer_length:
buf_list = (list(buffer))
# print(buf_list)
ser.flushInput()
# print(buf_list[0:23])
if buf_list[5] == 34:
# print("Water Info Received!")
sys_power = buf_list[9]
sys_power_text = "Off"
set_temp = (((buf_list[11]/2)*9/5) + 32)
outlet_temp = (((buf_list[12]/2)*9/5) + 32)
inlet_temp = (((buf_list[13]/2)*9/5) + 32)
wtr_flow = round(((buf_list[18]/10)* 0.2642),2)
unknown_flow = buf_list[19]
print(" ")
print("*************Water Information**************")
print(" ")
if sys_power == 5:
sys_power_text= " On"
print("The Power is: ",sys_power_text)
elif sys_power ==0:
sys_power_text= " Off"
else:
print("The Power is Unknown")
print("The Outlet Temp is: ",outlet_temp,"",u"\u00b0","F")
print("The Setpoint is: ", set_temp,u"\u00b0", "F")
print("The Water flow is: ",wtr_flow, "GPM")
print("The Inlet? Temp is: ",inlet_temp,"",u"\u00b0", "F")
print("The Unknown flow is:",unknown_flow, " GPM")
elif buf_list[5] == 42:
# print("Gas Info Received!")
print(" ")
print("**************Gas Information***************")
print(" ")
total_gas_use = round(((buf_list[24]/10)*0.3508),2)
low_byte_kcal = (buf_list[22])
high_byte_kcal = (buf_list[23])
total_kcal = high_byte_kcal + low_byte_kcal
print("Total Gas Usage is: ", total_gas_use, "therm")
print("Low Byte kCal is: ", low_byte_kcal, "kCal")
print("High Byte kCal is: ", high_byte_kcal, "kCal")
print("Total kCal: ", total_kcal, "kCal")
else:
pass
print("Bad Packet")
time.sleep(1)
except:
pass
This was successful enough to produce the following output.
The Power is: On
The Outlet Temp is: 63.5 ° F
The Setpoint is: 140.0 ° F
The Water flow is: 0.0 GPM
The Inlet? Temp is: 68.9 ° F
The Unknown flow is: 0 GPM
Total Gas Usage is: 2.17 therm
Low Byte kCal is: 0 kCal
High Byte kCal is: 0 kCal
Total kCal: 0 kCal
So having this information I went towards my final goal of using ESPHome to create this similar interface. Below is the ESPHome Config.
# Include basic info in all ESP Home Configs
# Basic Info Includes
# logger:
# wifi:
# ap:
# web_server:
# captive_portal:
# button: to restart the device
<<: !include .base1.yaml
esphome:
friendly_name: Navien Water Heater
includes:
- uart_read_line_sensor.h
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: NONE #makes uart stream available in esphome logstream
baud_rate: 0 #disable logging over uart
# Enable Home Assistant API
api:
encryption:
key: "redacted"
ota:
password: "redacted"
substitutions:
comment: "redacted"
globals:
- id: byte_timer
type: int
initial_value: "1"
interval:
- interval: 5s
then:
- lambda: |-
id(byte_timer) = (id(byte_timer) + 1);
if (id(byte_timer) > 25) {
id(byte_timer) = 1;
# Example configuration entry
uart:
tx_pin: 1
rx_pin: 3
baud_rate: 19200
data_bits: 8
stop_bits: 1
parity: NONE
debug:
direction: BOTH
dummy_receiver: false
after:
delimiter: "\n"
- lambda: |-
UARTDebug::log_string(direction, bytes);
//looking at this string f7 05 50 50 90 22 42
//where the 22 represents water information to follow
//and in the same byte if the number is 34 it is
//representative of gas information
if (bytes[0] == 247 && bytes[5] == 34) {
//id(uart_byte0).publish_state(bytes[0]);
//id(uart_byte1).publish_state(bytes[1]);
//id(uart_byte2).publish_state(bytes[2]);
//id(uart_byte3).publish_state(bytes[3]);
//id(uart_byte4).publish_state(bytes[4]);
//id(uart_byte5).publish_state(bytes[5]);
//id(uart_byte6).publish_state(bytes[6]);
//id(uart_byte7).publish_state(bytes[7]);
//id(uart_byte8).publish_state(bytes[8]);
//id(uart_byte9).publish_state(bytes[9]);
//id(uart_byte10).publish_state(bytes[10]);
id(set_temp).publish_state(((bytes[11]/2)*9/5) + 32);
id(outlet_temp).publish_state(((bytes[12]/2)*9/5) + 32);
id(inlet_temp).publish_state(((bytes[13]/2)*9/5) + 32);
//id(uart_byte14).publish_state(bytes[14]);
//id(uart_byte15).publish_state(bytes[15]);
//id(uart_byte16).publish_state(bytes[16]);
//id(uart_byte17).publish_state(bytes[17]);
id(water_flow).publish_state((bytes[18]/10)* 0.2642);
//id(uart_byte19).publish_state(bytes[19]);
//id(uart_byte20).publish_state(bytes[20]);
//id(uart_byte21).publish_state(bytes[21]);
//id(uart_byte22).publish_state(bytes[22]);
//id(uart_byte23).publish_state(bytes[23]);
//id(uart_byte24).publish_state(bytes[24]);
} else if (bytes[0] == 247 && bytes[5] == 42) {
id(low_byte_kcal).publish_state(bytes[22]);
id(high_byte_kcal).publish_state(bytes[23]);
id(total_gas_use).publish_state((bytes[24]/10)*0.3508);
} else (bytes[0] != 247); {
switch:
name: "HW Heater On/Off"
restore_mode: ALWAYS_ON
lambda: |-
if ((id(navien_switch).state) != (id(navien_switch).state)) {
return true;
} else {
return false;
turn_on_action:
- uart.write: !lambda
return {0xf7, 0x05, 0x0f, 0x50, 0x10, 0x0c, 0x4f, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xce};
id(navien_switch).publish_state(true);
turn_off_action:
return {0xf7, 0x05, 0x0f, 0x50, 0x10, 0x0c, 0x4f, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xa};
id(navien_switch).publish_state(false);
text_sensor:
- platform: custom
lambda: |-
auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
App.register_component(my_custom_sensor);
return {my_custom_sensor};
text_sensors:
text:
name: "Temp Set - Write"
optimistic: true
min_length: 0
max_length: 5
mode: text
on_value:
then:
- sensor.template.publish:
state: !lambda |-
auto n = parse_number<float>(x);
return n.has_value() ? n.value() : NAN;
# - platform: template
# name: "Byte 0"
# id: uart_byte0
# name: "Byte 1"
# id: uart_byte1
# name: "Byte 2"
# id: uart_byte2
# name: "Byte 3"
# id: uart_byte3
# name: "Byte 4"
# id: uart_byte4
# name: "Byte 5"
# id: uart_byte5
# name: "Byte 6"
# id: uart_byte6
# name: "Byte 7"
# id: uart_byte7
# name: "Byte 8"
# id: uart_byte8
# name: "Byte 9"
# id: uart_byte9
# name: "Byte 10"
# id: uart_byte10
name: "Temp Set - Read"
unit_of_measurement: °F
accuracy_decimals: 2
# name: "Byte 14"
# id: uart_byte14
# name: "Byte 15"
# id: uart_byte15
# name: "Byte 16"
# id: uart_byte16
# name: "Byte 17"
# id: uart_byte17
unit_of_measurement: GPM
# name: "Byte 19"
# id: uart_byte19
# name: "Byte 20"
# id: uart_byte20
# name: "Byte 21"
# id: uart_byte21
# name: "Byte 22"
# id: uart_byte22
# name: "Byte 23"
# id: uart_byte23
# name: "Byte 24"
# id: uart_byte24
name: "Total Gas Use"
unit_of_measurement: therms
name: "kCal Low Byte"
unit_of_measurement: kCal
name: "kCal High Byte"
internal: True
This seems to produce similar results as what I was seeing with the python code.
It looks like this:
I’m struggling with a few things here that I could use some tips on.
When using the switch I created in ESPHome to turn on/off the Heater, ideally I’d like the switch to set it’s position based on the current status of the unit, then if the switch changes - send the appropriate command. Last, I’d like to know that the command was received and that it has gone into that mode.
Similar question regarding the setpoint. In my config, I created a second “write” setpoint to try and begin configuring this function - but I’m not sure where to go from here.
In both of those cases, I’d like to have a single value/entity show on the ESPHome web page or entity in HA.
Any and all feedback is appreciated if you see something else here that would make this project better!
Hope this helps someone as they dive into their journey of doing the same!
Excitedly watching this from the sidelines! I have a NPE-240A2 that I’d love to monitor and control via HASS, ideally without the dreadful NaviLink experiences detailed above (and elsewhere on the web).
I’m a beginner with microcontrollers and ESPHome. Might poke around a bit with the above config and an 8266; still very much in the learning phase though.
@tsquared: Your code for uart_read_line_sensor.h
appears to be python2. Curious if there’s a reason for this, since both MicroPython and ESPHome support python3? I’m happy to refactor it for python3 and implement a few best practices, unless there’s a technical dependency on py2.
What interface did you use to communicate over rs485 with the Navien heater? I have an NPE240A and would love to ditch the Navilink in favor of a local ESP32 solution! Thank you so much for sharing your work!
Hello @brystmar! To be brutally honest, I am not a python or C programmer by any means. I have been using google, and just searching and patching lines of code together, and think I did ok to get here. I am confident there is a more elegant solution for all of this. So - certainly if you know of a better/different way - I am all ears!
As it relates to the 8266 and doing this - there was a reason I used the ESP32, and I think it had to do with the number of UART’s on it, but I don’t specifically recall what I read that pointed me in that direction.
To answer your question regarding the uart_readline_sensor.h
Not knowing how to program in C, or utilize the lambdas well enough to get the information out of the ESP32 that I have connected to the Navien, I utilized the Custom UART Text sensor listed here. Then, I utilized pieces of the code found in this thread. And coupled it with information found in this thread to get as far as I have. Again, Certainly not elegant, or likely efficient - but none-the-less, a semi-working copy!
You are more than welcome to refactor, or help with further development on this as I am sure we could all enjoy not having to use the Navilink Solution. Please let me know if I can provide more information.
@aruffell Currently, I have the following hooked up, and hoping to streamline it a bit further shortly.
From the 5 Pin Connector @ Navien to RJ-45 Connector - I purchased this
Once at the RJ45, I used a breakout connector that I purchased here
Then I wired the output of that breakout to the input of this
Then hooked the other end of that device, to the ESP32.
I’d have to get back to you on the wiring between all of this as I am not in front of those devices currently.
Let me know if you need more!
Ah, I misread your earlier post. Sounds like that python code was merely a proof of concept before attempting the ESPHome solution, so there’s no need for a refactor. I’m sure someone with more experience in the ESPHome microcontroller world can help optimize that config.
We can definitely simplify things on the hardware side. No need for that proprietary Navien cable or any of the RJ45 adapters either. A properly sized 5-pin molex connector + some jumpers from your local hobby store should do the trick. The tricky part is identifying the exact shape & size of that connector. These types of connectors are typically sold in bulk for pennies apiece. Another task for someone with more experience in this space
Have you considered starting a dedicated thread in the ESPHome category? You’re already most of the way there, just need some tweaking of the existing solution from someone with the right experience.
I have that cable and can take a look if I recognise the connector. I have a few connector kits I use to crimp my own cables so with some luck…
As for yhe rs485 adapter I see it coverts to 5V but that is not ideal for the esp32 as it is 3.3v, and only 5v tolerant. I did a quick search and saw some converters that have an rj45 connector on them or the space to solder one to simplify connection… however if we make our own cable, we can skip the rj45 connectors altogether as you suggested.
I was going to ask how @tsquared was powering his esp32. We are targeting a self-powered solution (i.e.: drawing power from the Navien’s board), even if it needs to be stepped down to 3.3v, yes?
@brystmar - Correct, the Python was certainly my proof of concept!
You make a good point about making a dedicated thread in the ESPHome category. I’ll have to check that out. Not sure if I link back to this, or create a new one?
@brystmar Correct, self powered is the ultimate goal here. I know that on the 5 pin connector @ the Navien board, there are only 4 wires. RS-485 RX/TX and also 12VDC & GND. I’m thinking about powering it from the 12 VDC and using one of these to step the voltage down to power the ESP32 & the RS-485 board.
I have included some pictures of the 5 pin connector if that helps anyone trying to cross reference it.
I have included a picture of my RJ-45 breakout for the pinout. The 4 wires I have labeled here are the only 4 in use. I left the rest hooked up as they were all attached to the ribbon like cable and didn’t see the need to tear it apart.
@aruffell You mention something about a RS-485 converter board with RJ-45 connectors? Would you have a link for this? Also, as it relates to the 5V/3.3V on the current converter board, it seems to be working as the current solution. I am not sure which voltage you are concerned about. Though I haven’t measured it, the secondary side of that board, is directly connected to one of the ESP32 UART’s and it seems to be handling it ok.
Anyway - hope this helps!
Cheers!
@tsquared I would ask a mod to most post x (fill in) down to the last into a new thread in the esphome section.
The GPIO of the esp32 is 3.3V and only 5V tolerant so whole it works it would be better to use a rs485 to 3.3V board. I will look for one and report back. I will also dig into digikey / mouser to see if I can pinpoint that connector. Do you see any numbers or letters marked on the connector?
Edit: Could it be this one - VHR-5N JST Sales America Inc. | Connectors, Interconnects | DigiKey
Apologies in advance, I don’t know how/who to ask to move the topic, and unfortunately created a post in the ESPHome category before I realized that @aruffell posted that this could be moved. Do you just @ a moderator and they should see it?
If it does move, it probably should begin starting with the post below.
The ESPHome category post is here for combining/changing etc.
Please let me know if I need to do something else.
Thank you all for your help here! Certainly appreciated!
Also, @aruffell Awesome find here! The connector you show certainly looks like the one I have. Do they usually come with any of the internal pins that you would need to connect the wires? Or can you get them with wires attached.
Could you post pinout of that connector? Which one is 12VDC, which are RS485 and ground pins.
I am thinking of using this RS485 base and add this controller to it. It seems that in that case it can directly power controller from 12VDC input of RS485 and looks neat. They also have RS485 in other forms for other controllers, also with 12-24VDC input to power controller.
