I’ve lost my neato vacuums completely after a recent restart/rebuild.
I’m using 0.88.2 and I get the following in the logs:
Thu Mar 07 2019 10:08:07 GMT+0000 (Greenwich Mean Time)
Setup of neato is taking over 10 seconds.
and…
neato: Error on device update!
File "/usr/src/app/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/app/homeassistant/helpers/entity.py", line 348, in async_device_update
await self.hass.async_add_executor_job(self.update)
File "/usr/src/app/homeassistant/components/neato/vacuum.py", line 189, in update
robot_map_id = self._robot_maps[self._robot_serial][0]['id']
IndexError: list index out of range
Any ideas on what i’ve done wrong? The vacuums previously showed up and worked fine!
I’ve not seen my Neato Vac since the latest update
Looks like the same problem.
Log Details (ERROR)
Thu Mar 07 2019 20:04:18 GMT+0000 (Greenwich Mean Time)
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 248, in _async_add_entity
File "/usr/local/lib/python3.7/site-packages/homeassistant/helpers/entity.py", line 348, in async_device_update
File "/usr/local/lib/python3.7/site-packages/homeassistant/components/neato/vacuum.py", line 189, in update
Yup this will be fixed in 0.89.1 there was an issue in 0.89 when we introduced zone/custom cleaning. The issue is that some botvac models report that they have a map but no ID. We are now skipping those models entirely for the update check.
