Neato D7 vacuum cleaner is not updating
Why will my Neato D7 won’t show updated values?
The connection is OK, I can start, stop and sent him back to his station via Home Assistant, this is not the problem.
BUT
The battery level stays continuous at 97%. (also before and after a +/- 40 min. cleaning cycle)
When he is cleaning, HA says he is docked.
Is anybody else experience this problem?
YES!!! I have a D4, with the same problem. Start/Stop, map etc work fine. But ‘clean start’, ‘clean stop’ don’t update till reboot it seems.
Really annoying as I’m using ‘clean stop’ to determine if another clean is due when I go out.
Think I’ll raise a bug when I get time.
:slight_smile:
what is the difference between “clean start” and “start” ?
the out of sync state mentioned up above was actually a neato cloud issue that was resolved a few days later too. it happens from time to time.
