I have had to re-install the Neato Integration after the last update. im now getting a redirect error from the Neato Web site. as in the screen capture. Anyone know what is going on and how to fix it?
Thx.
D
it woudl be helpful if you told us what URL you tried to use. Just remove the host but we need to see the format. Did you make sure to follow the updated steps on the docs?
https://emj8fu7vd5vfyq5eitocwp6y97m???.ui.nabu.casa/auth/external/callback
From Home assistant Cloud. ??? replaces real numbers
and you have remote URL turned on and are you accessing HA using that URL?
If I pas the URL without the auth/external/callback I get the logging screen for Home Assistant.
make sure to login to HA using the nabu casa URL before attempting to authorize the integration.
That was it!, Thx. it is always the small things.
