I’m using the Neato integration and it all works fine apart from every night at exactly midnight the vacuum gets sent out. I have checked the logs in home assistant and from what I can see it’s not being trigged by HA. If I use the neato app and check the HA logs they look the same. I have factory defaulted the vacuum and removed it from the app etc to make 100% sure there are no other schedules anywhere but it still comes out. I am now in the process of disabling individual components to see what happens. Has anyone else had this problem?
