Neato vacuum integration no longer works
I used to use Neato vacuum robot integration - just had oauth creds (neato_client_id and secret) configured in secrets.yaml, and apart for no-go lines it worked just fine.
Some time ago (about a month) it stopped working, and I recently tried to get it back alive.
It looks like when I add the integration now, after entering secrets in web UI popup (weren’t there before) I am being redirected to neato, but the redirect url seem to be wrong.
It does not point to my home instancce and port, but it looks like follows:
https://apps.neatorobotics.com/oauth2/authorize?client_id=XXXX&client_secret=XXXXX&redirect_uri=https%3A%2F%2Fmy.home-assistant.io%2Fredirect%2Foauth&response_type=code&scope=public_profile+control_robots+maps&state=XXXXXX
Neato returns “The redirect uri included is not valid.” error.
Can anyone advise what is happening?
Hi, did you get anywhere with this? Same problem.
Thanks.
No worries, found solution here New Neato Integration Installation Guide (OAuth2 for HA version 2021.1) - #88 by flysen
