Nedis IP-camera and smoke detectors
Is it possible to add my IP camera and smoke detectors.
I cant find a app that is working with Home Assistant, is their a other way to connect them to Home Assistant?
Nedis is really quite closed with information about their products.
They try to built their own eco-system and then lock you in it when you buy one of their devices.
Some have found a way to reflash a few plugs with tuya firmware, but often that just means it can be added as a cloud pulling device, which is the worst kind.
You can see a previous thread here, but it will probably be try and error with lots of tinkering.
I guess I made the mistake to purchase a Nedis camera and smoke detectors. Is the best way still to connect it using Tuya and then try local tuya to get it all local?
– Paul
