Hi there,
I have pi3 with raspbee and hassio up an running. All seems good after some struggle with deconz which was cause by a bit of simple error. Ihave installed from: https://bitbucket.org/jongsoftdev/hassio-addon/src/505390c9603566ae999c72c29bbdffa52095424f/dresden-deconz/?at=master and followed instruction but could not get it works. And finally I have found on inet that lines:
enable_uart=1
dtoverlay=pi3-disable-btroot
btroot shout be just bt so:
enable_uart=1
After simply correction all suddenly start worked and deconz instantly was ready to configure I just unlock gateway and xiaomi smart plugs were discovered and showed up in the HASS panel.
Very happy started to do some automation via configurator and I got that automation.yaml file generaterd:
ction:
- service: light.turn_on
alias: TV light on
condition: []
trigger: - event: sunset
offset: -00:15:00
platform: sun - action:
- service: light.turn_off
alias: TV light off
condition: []
trigger: - at: ‘22:35’
platform: time
- action:
- service: switch.turn_on
alias: Floor lamp on
condition: []
offset: -00:45:00
platform: sun
- action:
alias: Floor lamp off
condition: []
trigger: - at: ‘22:50’
platform: time
I have to lamps and I want to turned it on and off but on different times but it does not work, all turn on/off at the same time for TV light.
I read a bit about it and seems to be lack of entity_id entry but I do not know where to add it or maybe I need to write yaml file in editor because examples it hass tutorial about automation looks a bit different.
Could you help me with these please.?
