I have this ESPHome config and it works in 2025.9.3, but not in 2025.10.X.
I get an error saying.
WARNING Can't connect to ESPHome API for onkyo @ 10.10.12.58: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='10.10.12.58', port=6053))]: [Errno 111] Connect call failed ('10.10.12.58', 6053) (SocketAPIError)
The funny thing is that I then can not connect to the logger stream, but I can still update the device, which means I can install ESPHome 2025.9.4 and OTA update it, which makes all work again.
If I try 2025.10.X again, then it will fail again. I have done it a couple of times just to be sure.
I hope someone can tell me, if I have done something wrong or if I have a bug.
I know that something happend with the arduino framework, but I tried to switch to esp-idf, but with no change in behavior.
The YAML config is here.
esphome:
friendly_name: Onkyo
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# baud_rate: 0
tx_buffer_size: 256
level: DEBUG
ota:
- platform: esphome
password: !secret esphome_ota_pass
wifi:
output_power: 20db
fast_connect: true
ssid: DWsh
password: !secret dwsh_pass
manual_ip:
static_ip: 10.10.12.58
subnet: 255.255.255.0
gateway: 10.10.12.1
dns1: 10.10.12.1
globals:
# Custom input names. Values set to be empty is skipped and can't be selected from here, but can still be chosen directly on the receiver!
# Also input names must be unique!
- id: vcr_dvr
type: std::string
initial_value: '"VCR/DVR"' # VCR/DVR
- id: cbl_sat
type: std::string
initial_value: '"MINIJACK"' # CBL/SAT
- id: game_tv
type: std::string
initial_value: '"PS3"' # GAME/TV
- id: aux
type: std::string
initial_value: '"AUX"' # AUX
- id: dvd
type: std::string
initial_value: '"SNAPCAST"' # DVD
- id: tape
type: std::string
initial_value: '"TAPE"' # TAPE
- id: phono
type: std::string
initial_value: '"PHONO"' # PHONO
- id: cd
type: std::string
initial_value: '"TV SOUND"' # CD
# Previous values for restoring when receiver return n/a
- id: previous_input
type: std::string
initial_value: '"N/A"'
- id: previous_listening_mode
type: std::string
text_sensor:
icon: mdi:video-input-component
on_value:
then:
- if:
condition:
- lambda: |-
if (id(input).state=="Not available") {
return true;
} else {
return false;
then:
- delay: 2s
- uart.write:
data: "1!SLIQSTN"
name: "Input Available"
on_value:
then:
- if:
condition:
- lambda: |-
if (id(listening_mode).state=="Not available") {
return true;
} else {
return false;
then:
- delay: 2s
- uart.write:
data: "1!LMDQSTN"
icon: mdi:surround-sound
name: "Listening Mode Available"
binary_sensor:
icon: mdi:power
icon: mdi:volume-variant-off
- platform: wifi_signal
- platform: uptime
icon: mdi:volume-high
button:
- platform: restart
- platform: factory_reset
name: Restart with Factory Default Settings
entity_category: "diagnostic"
api:
encryption:
key: !secret api_key
actions:
# Direct Onkyo Command
- action: write
variables:
command: string
then:
- uart.write:
data: !lambda |-
std::string str = command;
std::vector<uint8_t> vec(str.begin(), str.end());
return vec;
- uart.write:
data: "\r"
# Power
- action: power_on
then:
- uart.write:
data: "!1PWR01\r"
- action: power_off
then:
- uart.write:
data: "!1PWR00\r"
- action: power_update
then:
- uart.write:
data: "!1PWRQSTN\r"
# Mute
- action: mute_on
then:
- uart.write:
data: "!1AMT01\r"
- action: mute_off
then:
- uart.write:
data: "!1AMT00\r"
- action: mute_toggle
then:
- uart.write:
data: "!1AMTTG\r"
- action: mute_update
then:
- uart.write:
data: "!1AMTQSTN\r"
# Volume
- action: set_volume
variables:
volume: string
then:
- if:
condition:
lambda: |-
int new_value = stoi(((std::string)volume),0,10);
if (new_value<=100 && new_value>=0) {
return true;
} else {
return false;
then:
- uart.write:
data: "!1MVL"
- uart.write:
data: !lambda |-
int first = new_value/16;
char first_char;
switch (first) {
case 0:
first_char = '0';
break;
case 1:
first_char = '1';
break;
case 2:
first_char = '2';
break;
case 3:
first_char = '3';
break;
case 4:
first_char = '4';
break;
case 5:
first_char = '5';
break;
case 6:
first_char = '6';
break;
case 7:
first_char = '7';
break;
case 8:
first_char = '8';
break;
case 9:
first_char = '9';
break;
case 10:
first_char = 'A';
break;
case 11:
first_char = 'B';
break;
case 12:
first_char = 'C';
break;
case 13:
first_char = 'D';
break;
case 14:
first_char = 'E';
break;
case 15:
first_char = 'F';
break;
default:
first_char = 'Q';
break;
std::string str(1, first_char);
return vec;
- uart.write:
data: !lambda |-
int second = new_value - (first*16);
char second_char;
switch (second) {
case 0:
second_char = '0';
break;
case 1:
second_char = '1';
break;
case 2:
second_char = '2';
break;
case 3:
second_char = '3';
break;
case 4:
second_char = '4';
break;
case 5:
second_char = '5';
break;
case 6:
second_char = '6';
break;
case 7:
second_char = '7';
break;
case 8:
second_char = '8';
break;
case 9:
second_char = '9';
break;
case 10:
second_char = 'A';
break;
case 11:
second_char = 'B';
break;
case 12:
second_char = 'C';
break;
case 13:
second_char = 'D';
break;
case 14:
second_char = 'E';
break;
case 15:
second_char = 'F';
break;
default:
second_char = 'Q';
break;
std::string str(1, second_char);
return vec;
- uart.write:
data: "\r"
- action: volume_update
then:
- uart.write:
data: "!1MVLQSTN\r"
# Input
- action: set_input
variables:
input: string
then:
- if:
condition:
lambda: |-
if (input=="") {
return false;
} else {
return true;
then:
- lambda: |-
id(previous_input)=id(input);
- uart.write:
data: "!1SLI"
- uart.write:
data: !lambda |-
std::string str;
if (input==id(vcr_dvr)) { str="00"; }
if (input==id(cbl_sat)) { str="01"; }
if (input==id(game_tv)) { str="02"; }
if (input==id(aux)) { str="03"; }
if (input==id(dvd)) { str="10"; }
if (input==id(tape)) { str="20"; }
if (input==id(phono)) { str="22"; }
if (input==id(cd)) { str="23"; }
if (input=="FM TUNER") { str="24"; }
if (input=="AM TUNER") { str="25"; }
if (input=="MULTI CH") { str="30"; }
if (str.length()==0) { str="QSTN"; }
return vec;
- uart.write:
data: "\r"
- delay: 1s
- uart.write:
data: "!1SLIQSTN\r"
- action: input_update
then:
- uart.write:
data: "!1SLIQSTN\r"
- action: available_input_update
then:
- lambda: |-
std::string str;
if (id(vcr_dvr).length()>0) {
str.append(id(vcr_dvr));
if (id(cbl_sat).length()>0) {
if (str.length()>0) {
str.append(", ");
str.append(id(cbl_sat));
if (id(game_tv).length()>0) {
str.append(", ");
str.append(id(game_tv));
if (id(aux).length()>0) {
str.append(", ");
str.append(id(aux));
if (id(dvd).length()>0) {
str.append(", ");
str.append(id(dvd));
if (id(tape).length()>0) {
str.append(", ");
str.append(id(tape));
if (id(phono).length()>0) {
str.append(", ");
str.append(id(phono));
if (id(cd).length()>0) {
str.append(", ");
str.append(id(cd));
str.append(", ");
str.append("FM TUNER, AM TUNER, MULTI CH");
id(input_available).publish_state(str.c_str());
# Listening Mode
- action: set_listening_mode
variables:
mode: string
then:
- if:
condition:
lambda: |-
if (mode=="") {
return false;
} else {
return true;
then:
- uart.write:
data: "!1LMD"
- uart.write:
data: !lambda |-
std::string str;
if (mode=="STEREO") { str="00"; }
if (mode=="DIRECT") { str="01"; }
if (mode=="SURROUND") { str="02"; }
if (mode=="THEATER") { str="13"; }
if (mode=="MONO") { str="15"; }
if (mode=="PURE AUDIO") { str="17"; }
if (mode=="STRAIGHT") { str="64"; }
return vec;
- uart.write:
data: "\r"
- delay: 1s
- uart.write:
data: "!1LMDQSTN\r"
- action: listening_mode_update
then:
- uart.write:
data: "!1LMDQSTN\r"
- action: available_listening_mode_update
then:
- lambda: |-
id(listening_mode_available).publish_state("STEREO, DIRECT, SURROUND, THEATER, MONO, PURE AUDIO, STRAIGHT");
# Initialize settings
- action: update_all
then:
- uart.write:
data: "!1PWRQSTN"
- uart.write:
data: "\r"
- delay: 1s
- uart.write:
data: "!1AMTQSTN"
- uart.write:
data: "\r"
- delay: 1s
- uart.write:
data: "!1MVLQSTN"
- uart.write:
data: "\r"
- delay: 1s
- uart.write:
data: "!1SLIQSTN"
- uart.write:
data: "\r"
- delay: 1s
- uart.write:
data: "!1LMDQSTN"
- uart.write:
data: "\r"
- lambda: |-
std::string str;
str.append(", ");
str.append(", ");
str.append(", ");
str.append(", ");
str.append(", ");
str.append(", ");
str.append(", ");
str.append(id(cd));
str.append(", ");
- lambda: |-
uart:
- id: uart_onkyo
baud_rate: 9600
data_bits: 8
stop_bits: 1
parity: NONE
rx_buffer_size: 128
tx_pin:
number: GPIO17
inverted: false
rx_pin:
number: GPIO16
inverted: false
debug:
direction: RX
dummy_receiver: true
after:
bytes: 16
sequence:
- lambda: |-
UARTDebug::log_string(direction, bytes);
std::string str(bytes.begin(), bytes.end());
if (str.substr(0,2)=="!1") {
if (str.substr(2,3)=="PWR") {
if (str.substr(5,2)=="00") {
id(power).publish_state(false);
if (str.substr(5,2)=="01") {
id(power).publish_state(true);
std::string str;
str.append(", ");
str.append(", ");
str.append(", ");
str.append(", ");
str.append(", ");
str.append(", ");
str.append(", ");
str.append(id(cd));
str.append(", ");
if (str.substr(2,3)=="AMT") {
id(mute).publish_state(false);
id(mute).publish_state(true);
if (str.substr(2,3)=="MVL") {
id(volume).publish_state(stoi((std::string)(str.substr(5,2)),0,16));
if (str.substr(2,3)=="SLI") {
if (str.substr(5,3)=="N/A") {
id(input).publish_state("Not available");
} else {
switch (stoi((std::string)(str.substr(5,2)))) {
case 00:
id(input).publish_state(id(vcr_dvr).c_str());
break;
case 01:
id(input).publish_state(id(cbl_sat).c_str());
break;
case 02:
id(input).publish_state(id(game_tv).c_str());
break;
case 03:
id(input).publish_state(id(aux).c_str());
break;
case 10:
id(input).publish_state(id(dvd).c_str());
break;
case 20:
id(input).publish_state(id(tape).c_str());
break;
case 22:
id(input).publish_state(id(phono).c_str());
break;
case 23:
id(input).publish_state(id(cd).c_str());
break;
case 24:
id(input).publish_state("FM TUNER");
break;
case 25:
id(input).publish_state("AM TUNER");
break;
case 30:
id(input).publish_state("MULTI CH");
break;
default:
id(input).publish_state("NA");
break;
if (str.substr(2,3)=="LMD") {
id(listening_mode).publish_state("Not available");
} else {
switch (stoi((std::string)(str.substr(5,2)),0,16)) {
case 00:
id(listening_mode).publish_state("STEREO");
break;
case 01:
id(listening_mode).publish_state("DIRECT");
break;
case 02:
id(listening_mode).publish_state("SURROUND");
break;
case 13:
id(listening_mode).publish_state("THEATER");
break;
case 15:
id(listening_mode).publish_state("MONO");
break;
case 17:
id(listening_mode).publish_state("PURE AUDIO");
break;
case 64:
id(listening_mode).publish_state("STRAIGHT");
break;
default:
id(listening_mode).publish_state("NA");
break;
