[{"id":"8baacab4.686798","type":"api-call-service","z":"88ff0714.c96c08","name":"Off if 26 or higher","server":"2319e56d.dfc0ea","version":1,"debugenabled":false,"service_domain":"climate","service":"turn_off","entityId":"climate.varmepumpe","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":750,"y":160,"wires":[[]]},{"id":"9b059894.6628b8","type":"switch","z":"88ff0714.c96c08","name":"","property":"payload","propertyType":"msg","rules":[{"t":"gte","v":"26","vt":"str"},{"t":"gte","v":"27.5","vt":"str"},{"t":"lte","v":"20","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":530,"y":180,"wires":[["8baacab4.686798"],["ca9a4878.f91b28"],["a738cfd6.5e43c"]]},{"id":"6ef7e2fd.42796c","type":"poll-state","z":"88ff0714.c96c08","name":"Temp. sensor","server":"2319e56d.dfc0ea","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"updateinterval":"60","updateIntervalUnits":"seconds","outputinitially":false,"outputonchanged":false,"entity_id":"sensor.aeon_labs_zw100_multisensor_6_temperature","state_type":"str","halt_if":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"x":150,"y":180,"wires":[["9b059894.6628b8"]]},{"id":"a738cfd6.5e43c","type":"api-call-service","z":"88ff0714.c96c08","name":"On if 20 or lower","server":"2319e56d.dfc0ea","version":1,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.varmepumpe","data":"{\"temperature\":\"23\", \"hvac_mode\":\"heat\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":740,"y":280,"wires":[[]]},{"id":"ca9a4878.f91b28","type":"api-call-service","z":"88ff0714.c96c08","name":"Cool if 27.5 or higher","server":"2319e56d.dfc0ea","version":1,"debugenabled":false,"service_domain":"climate","service":"set_temperature","entityId":"climate.varmepumpe","data":"{\"temperature\":\"20\",\"hvac_mode\":\"cool\"}","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":760,"y":220,"wires":[[]]},{"id":"2319e56d.dfc0ea","type":"server","z":"","name":"Home Assistant","legacy":false,"hassio":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":false}]
Need some help with a few things here.
- In the call servive node “Cool if 27.5 or higher” and “On if 20 or lower” I want a delay of one second before sending the next command. Hassio gets both commands sent and updates the status, but it seems that broadlink only perceives the first command it receives.
"temperature": "20",
some kind of delay here?
"hvac_mode": "cool"
- Is it possible to make a switch for Hassio between “Temp.sensor” and “Switch” so that this automation can be switched off?
If smoke detectors detect smoke / heat then I want to turn off this automation (climate), unlock doors and so on …
