Can we configure a script to run after a successful renewal?
That way, I can script it to create a pfx file for Jellyfin. Thank you.
The folder watch integration can monitor file changes to your cert files. Automate based on that change.
Thanks, I managed to find the folder watcher, but any idea how I can run a bash script?
Really you need to look through the docs. Try searching
I found it. Thank you.
Sorry, not sure why but I now keep getting an error from folder_watcher
This is my entry in configuration.yaml
folder_watcher:
- folder: /ssl
patterns:
- '*.pem'
and the error is
Home Assistant Core
Setup failed for folder_watcher: Integration failed to initialize.
22:48:24 – (ERROR) setup.py
Folder /ssl is not valid or allowed
22:48:24 – (ERROR) folder_watcher
Nevermind, found it
homeassistant:
allowlist_external_dirs:
- /ssl
