Need a small starter to release new themes
Hello all together,
I’m currently creating a new set of themes. The finetuning of single values I will do after release.
As I wanted to start with the recommended structure for theme sets I tried this structure (stub):
frontend:
  themes:
    glass-magentaX:
      maincolor1: "#e60073"
      modes:
        light:
          maincolor2: "#00334d"
          highlight_color: "#ddd"
          contrast-color1: "#eee"
          texture-color1: "#2d8659"
          texture-color2: "#00334d"
          background-color: "#2d8659"
        dark:
          maincolor2: "#000"
          highlight_color: rgba(51, 204, 255, 1)
          contrast-color1: "#ddd"
          texture-color1: "#333"
          texture-color2: "#000"
          background-color: "#222"
  backgroundeffect: radial-gradient(farthest-corner at 50% 100%, var(--maincolor1) 30%, var(--maincolor2) 90%)
  styleeffect: linear-gradient(rgba(255, 255, 255, 0.5), rgba(255, 255, 255, 0.15) 10%, rgba(255, 255, 255, 0.15) 50%, rgba(0, 0, 0, 0.25) 50%, rgba(0, 0, 0, 0.25))
  totaleffect: var(--styleeffect), var(--backgroundeffect)
My problem is here, I want to define the main colors as they define the single themes. But after the “tree” of basic colors I want to go over to the common values. And then I got an configuration error as values like backgroundeffect ff are not in a tree but as values line by line.
When I can’t fix this I think about
  1. duplicate the whole code for every theme (as it is working now)
  2. copying the common values into the tree
Both solutions will blow up the themes and will make it hard to read.
So I’m happy to get a little help on start to configure the yaml. I will not write the code into the configuration yaml, so I already created the themes in the theme folder. This was easy as there were other HACS themes installed before.
