Need a sunlight_opacity sensor or my floor plan
Hi, i need help with the sunlight_opacity sensor for my floor plan. Could someone post a working sensor template?
thanks in advance
found it myself. If someone need it…
      sunlight_opacity:
        value_template: >-
          {%- set sunpct = states('sensor.sunlight_pct') | float %}
          {%- set opacity = sunpct / 100 | float %}
          {{ opacity }}
and
    sensors:
      sunlight_pct:
        entity_id:
          - sun.sun
          - sensor.openweathermap_cloud_coverage
        value_template: >-
          {%- set elevation = state_attr('sun.sun','elevation') | float %}
          {%- set cloud_coverage = states('sensor.openweathermap_cloud_coverage') | float %}
          {%- set cloud_factor = (1 - (0.75 * ( cloud_coverage / 100) ** 3 )) %}
          {%- set min_elevation = -6 %}
          {%- set max_elevation = 60 %}
          {%- set adjusted_elevation = elevation - min_elevation %}
          {%- set adjusted_elevation = [adjusted_elevation,0] | max %}
          {%- set adjusted_elevation = [adjusted_elevation,max_elevation - min_elevation] | min %}
          {%- set adjusted_elevation = adjusted_elevation / (max_elevation - min_elevation) %}
          {%- set adjusted_elevation = adjusted_elevation %}
          {%- set adjusted_elevation = adjusted_elevation * 100 %}
          {%- set brightness = adjusted_elevation * cloud_factor %}
          {{ brightness | round }}
        unit_of_measurement: '%'
        device_class: 'illuminance'
